Old 09-27-2016, 03:06 PM   #1
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
Slight steering wheel shake after wider wheels installed
I went 20X9 on all 4 corners, 257/40/20
Slight shake in the steering wheel at cruise, the roads where I live are pretty rough and I can't figure out if the wider wheel is feeling every bump in the road or if I need an alignment.
I am 60,xxx miles in, so an alignment on these rough roads probably won't hurt anything, but I am just wondering if anyone else has experienced this? Loving the FR replicas, and they are balanced for information sake.
Thanks!
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
NC_SS is offline   Reply With Quote
Old 09-27-2016, 03:08 PM   #2
failshift
Banned
Alignment. And make sure they're balanced correctly
failshift is offline   Reply With Quote
Old 09-27-2016, 03:12 PM   #3
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
Check,
1. Wheels are installed straight and true with nuts properly torqued
2. Have another shop rebalance the wheels. Road force balancer is better than generic one. Most gm dealers have one
3. Check alignment
4. Inspect for loose parts, ball joints, tie rods etc
5. Inspect for seized brake caliper
I would say they arent balanced well in my opinion. Since you didn't have issues before. Some shops I've had to go back 3 times before they would get balancing right on the wide wheels.
SnowyCamaro is offline   Reply With Quote
Old 09-27-2016, 03:14 PM   #4
NC_SS
NC_SS's Avatar
Calling a GM dealer right now to setup an appointment to have them checked
Old 09-27-2016, 03:15 PM   #5
failshift
Banned
Just got to discount tire
Dealer gonna charge prime
Old 09-27-2016, 03:19 PM   #6
NC_SS
NC_SS's Avatar
Service advisor said it'd be about $40 and they have a road force balancing machine
I can swing $40
Old 09-27-2016, 03:19 PM   #7
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Wheel out of round? What manufacturer?
its a syn is offline   Reply With Quote
Old 09-27-2016, 03:31 PM   #8
NC_SS
NC_SS's Avatar
Factory Reproductions
Called those guys as well and they said they'd send me another wheel if that was the case.
Old 09-28-2016, 04:17 PM   #9
NC_SS
NC_SS's Avatar
UPdate
Tech said he doesn't think the wheels are out of round, and that it wasn't balanced properly so I'm going back tomorrow for road force balancing
Old 09-28-2016, 08:24 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Did the same setup of 20x9s and 275s all around using factory cast 5 spoke an no problems.
Orange Krush II
Old 09-28-2016, 08:36 PM   #11
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Maybe missing spacer? Happened once with my winter wheels.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 09-29-2016, 06:53 PM   #12
NC_SS
NC_SS's Avatar
All 4 wheels were out of balance lol
Old 10-01-2016, 09:30 PM   #13
Fignewton
Fignewton's Avatar
Drives: 2010 2SS
One thing I have found over the years is you can have some slight rust build up on the rotor that can interfere with a new or different wheel mounting completely flush. I always clean both mounting surfaces with a 3m disc and/or a small wire wheel on a drill.
Fignewton is offline   Reply With Quote
Old 10-02-2016, 02:32 PM   #14
SnowyCamaro
I Always need to get them double checked. Wide wheels with tape weights always seems like most shops I've dealt with can't manage to get them right on the first try.
