11-19-2020, 05:41 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
BMR Drag Pack, Xtreme anti-roll bar, and 15 inch racestars. How to setup?
I've got everything installed and I'm ready to time the bushings, set ride height, and fix the anti roll bar.
But to be honest, I dont know where to begin. I have the car (wheels on) up on blocks. I've taken a good guess on the alignment bolts (used the old marks for reference). In which order do I proceed? Set the ride height first, or try to get the lca's as level as possible and let the ride height fall where it may? When attaching the anti roll bar end links to the lower control arms, does it need to be preloaded? Leave it loose? Which hole should I use? Then I also need to figure out where to start with the compression and rebound settings on the Strange adj coilovers. Feeling a little overwhelmed. Pics coming.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-19-2020, 05:44 AM | #2 |
Stuffing a 325/50/15 in there isnt easy, but i think they’re in.
11-19-2020, 03:29 PM | #3 | |
Drives: Race Car Join Date: Sep 2009
Antiroll Bar 2/3 holes Shock Settings 5/9 Rebound - 4/9 Compression |
11-22-2020, 10:00 AM | #4 | |
From 40mph i get some spinning (maybe cold tires) and then a good hook. Ill work on it some more when the weather dries up. I did get a little floaty hooptie feeling going through a bumpy intersection, so maybe ill tighten it up one more click. A local guy has the same setup, but drag only, and runs them at pretty much max. The 325s fit.
12-23-2020, 05:41 AM | #5 |
Is anyone else running this same setup? I'm having a few issues.
The balancing weights on the wheels hit the calipers and came off. Which is strange because I bought the wheels and brakes from the same guy and he ran them together. The trailing arms are contacting the wheels when I make a left turn at an intersection for example. Basically turning either direction and causing the rear coilovers to compress will create contact between the trailing arm and wheel. It is not the E Brake cable. I have a noticeable grind on the trailing arm where the red powder coating has been removed. I also have alot of clicking and banging going on back there. I jacked the car up and raised the coilover spring plate about 3/8''. I also increased the compression and rebound to 8 and 7. I'm hoping the higher ride height and stiffer suspension will allow less travel. I purchased the SPC camber and toe bolts and would like to take it in for alignment, but it would be a waste of time and money if my ride height changes, or I have clearance issue that need to be addressed.
12-24-2020, 05:14 AM | #6 |
Raising the car by 3/8" has fixed the rubbing issue. But I'm still not able to hook up even rolling into 3rd gear. I definitely have a suspension issue. I guess its time to find a chassis shop.
12-24-2020, 07:21 AM | #7 |
8.60 @ 157 @ 4200lbs
Suspension
This is hard one every setup is differant. Alignment is super critical on these cars stock vs drag setup. My drag setup alignment i still drive on street. Need to weight car see your front and rear weight. Other things to try to have some video or if you can tell. Say rear tires hook then lose traction - increase rebound slowing the rate at which front end rises prevent shock from topping out. Does car still have front sway bar if so unhook it for test or just remove. What front shocks do you run if factory, look into Lakewood front strut run a 70/30 . i know jumping around alot just trying give info. Then to your anti roll should be set no preload to begin with.
2010 camaro twin turbo 8.60 @ 157 full weight 4200
12-24-2020, 08:43 AM | #8 | |
When I installed the anti sway bar, I left it disconnected until the ride height was set, then I rotated the bar so the forks were parallel with the ground, then spun the rod ends to adjust the length, then put the bolt through the lower control arms and tightened. But come to think if it, I have adjusted the ride height and moved the bar to the middle setting since then. I may have to check if there is preload now. About the weight, im sure the front is heavier, especially with the iron block and SC. I've also removed the interior, which probably took more weight off the back, than it did the front. Come to think of it, the car seems to act better with a full tank of gas. I need to get some weight off the nose.
12-24-2020, 08:44 AM | #9 |
Is this car Automatic?
12-24-2020, 09:06 AM | #10 |
Drives: 2010 SS L99 Join Date: Sep 2018
Did you take out the AC and the washer bottle? Thats almost a good 60-65 lbs right there. And what front brakes do you run? The Aerospace brakes are light!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
12-24-2020, 09:15 AM | #11 |
The washer bottle is gone, but I haven't let go of the AC yet. In Florida its not optional for a street driven car. Which this is quickly unbecoming...
12-24-2020, 09:26 AM | #12 |
What front brakes? Aerospace makes some light ones
12-24-2020, 10:15 AM | #13 |
No need to remove ac or heat im still running mine. Dont give up your problly closer than you think on getting it to hook. But knowing your front and rear weight help us figure out setup
12-24-2020, 12:29 PM | #14 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
I run Viking coil overs all around with BMR drag setup.Sent the weight of the car at all 4 corners to Viking and I'm running a higher spring rate up front because of the extra weight VS stock.Big difference in weight transfer and drives nice.Vikings has alot of adjustability,road course,street,comfort,drag race. I dead hook on the street with 20" drag radials. Still have the front sway bar hooked.
BUT I have a boost controller to control the power down low.and mine is a automatic.I do sometimes loose just a little bit of traction in high gear at 120mph when my converter locks up.20" can only do so much. No issues with the 17",and I'm thinking of going with 15". Either way, I think it will be VERY hard to apply ALL the power that you have on a normal street surface.I would think a Bias rear tire would be better for you because you have a manual.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
