08-11-2020, 03:20 PM | #1 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
What is the proper way to clean a Camaro engine bay?
What is the proper way to clean a Camaro engine bay? Which vital components are you covering up to prevent damage from soap and water?
08-11-2020, 03:32 PM | #2 |
I just use a micro fiber cloth and some detailing spray and wipe EVERYTHING I can get to.
08-11-2020, 04:25 PM | #3 |
My Road Rage is Legendary
That looks good.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
08-11-2020, 04:31 PM | #4 |
Drives: 2015 BLK/BLK 2SS/RS MN6 Join Date: Oct 2016
I soak my whole engine bay underhood included with Simple Green. Let it sit 5-10 minutes. Spray again the dry spots maybe. Use a sponge or rag on dirty spots if any. Spray it down with a hose avoiding the obvious intake and electrical components. I've never had a problem.
08-11-2020, 04:47 PM | #5 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Like what was mentioned above. I use detail spray and micro fiber towels. The key is to never let the engine bay get real dirty. Wipe it down after every wash and you will be pleased with the results. Here’s a pic of my 10 year old engine bay.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
08-12-2020, 08:01 AM | #6 |
Thanks sir. Yea 116k miles and is a daily 10 years old!!
08-12-2020, 08:04 AM | #7 |
As DAB says above, the KEY to having a clean engine bay is to NEVER let it get dirty. Another thing is when you do use a micro and detail spray, let the engine bay cool down considerable before you do it so you don't burn yourself and the spray doesn't dry on the components and you have to do it twice. 10 year old Camaro with 116k miles on her and is a daily driver. Good luck.
08-12-2020, 08:37 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Never get it dirty.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-12-2020, 09:29 AM | #9 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I use Simple Green with a 3" paint brush on the outer perimeter items including the shock towers and inner fenders. Then use a Light hose spray to rinse it off. It gets all the nooks and crannies clean. I then dry everything including the engine top. My SS is 11 years old now and still looks great. There's no reason to soak or rinse the engine itself.
08-13-2020, 12:30 PM | #10 |
Drives: 2010 2SS RS LS3 Join Date: Jul 2017
Go to youtube and search for Chris fix cleaning engine bay. Great DIY. I did it 2 weeks ago.
08-13-2020, 02:44 PM | #11 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
My SS is 10 years old. Here is a picture of it.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
08-13-2020, 04:29 PM | #12 | |
Drives: Never just fly under the radar Join Date: Jul 2015
I have trouble cleaning around the coil packs on the holley valve covers. Any ideas appreciated!
Old Skool |
08-14-2020, 02:40 PM | #13 | ||
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
Why do just the engine bay?
08-14-2020, 11:44 PM | #14 |
Here's my go-to for cleaning the engine bay...
https://youtu.be/PRSoRkM8GcM
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
