Old 06-28-2011, 09:48 AM   #1
bigwayne3000
Drives: 2011 Camaro LS
Mix of wash and water in foam gun
I can never get the mixture right when using my foam gun. I have a Foamaster II gun and use Adam's wash. When I use the gun it doesn't come out very foamy, instead its very watered down so im looking for any tips that will help me get the right mix.
bigwayne3000 is offline   Reply With Quote
Old 06-28-2011, 10:16 AM   #2
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
The holes in the center bar should face up and you move it one way or the other to adjust mixture. The screw on the end also changes the flow.
Adams shampoo is very thick so you might want to try thinning it down some or the vacuum may not be able to draw enough concentrate up the tube to make good foam. I have an Adams gun for their soap and a foamaster for my daily drivers and another brand soap.
MMC is offline   Reply With Quote
Old 06-28-2011, 10:23 AM   #3
Tecca
Tecca's Avatar
Drives: ...
Are you filling the bottle up with water after you put the soap in???
Tecca is offline   Reply With Quote
Old 06-28-2011, 10:39 AM   #4
bigwayne3000
Yes I am. Should I be doing this the other way ie. Water than the soap? Didnt think it'd matter.
Old 06-28-2011, 11:11 AM   #5
Tecca
Tecca's Avatar
Drives: ...
No your fine, I have known people that just put soap in the bottle with no water.
How much soap are you using. Never had this problem then again I never cared for adam's soap (big surprise)
What ratio setting are you using also.....
Old 06-28-2011, 11:14 AM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Whats the ratio you're using? How many oz's of soap in a full bottle mixture?
Old 06-28-2011, 11:25 AM   #7
bigwayne3000
Not sure how many oz I use as I just squirt the shampoo in until I feel like it's enough. I have no way to measure oz or anything. I use a good amount of shampoo though and it's on setting 6 I believe, I'd have to go look.
Old 06-28-2011, 11:29 AM   #8
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
I use Turtle Wax Ice Car Wash undiluted in mine, with the setting on the third hole. Works great!
Tallboy is offline   Reply With Quote
Old 06-28-2011, 11:32 AM   #9
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I put in about two shot glasses of Adams and the rest water in mine and move the slide to max. That seems to work well for me.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-28-2011, 12:09 PM   #10
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I put about 3/4" inch of soap in then fill with water and use the second to foamiest setting. Works great for me. ( Adam's shampoo)
[B]
Old 06-28-2011, 12:16 PM   #11
Adam's Polishes
Get yourself a cheap kitchen measuring cup for use in the garage... it comes in very handy for doing more specific metering. The one I'm using now was $0.99 in the clearance bin at Target.
Personally I've found a mixture of about 3-6oz of soap per FULL water canister is ideal. The range is primarily b/c your hose pressure also plays a large roll in how the gun will foam.... with low pressure the gun will not pull soap as effectively, won't introduce as much air, and won't create as much foam as compared to a higher pressure source.
I'd say start in the middle... somewhere around 4-5oz and go up or down from there to get a feel for it.
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 125 02-05-2024 09:55 PM
Whats the proper method for dust removal Strokedhog Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 35 12-01-2010 08:40 PM
Car Washing.................... Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 03-08-2010 06:48 PM
Wash your car... The right way. henrythomas Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 10-23-2009 01:06 AM
Mr Clean Auto Dry & waterblade? Matt'sSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 08-17-2009 12:19 PM
