01-16-2020, 12:12 PM | #1 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
How to dial in more oversteer?
I have Hotchkis 32mm front and rear sway bars on my car. I'm thinking I may have too much understeer due to the 0mm bias I have between the bars. I remember Justice Pete stating that you want a 4mm to 6mm difference in bias between bar thickness.
I am running the three way adjustable rear bar on the stiffest setting. From what I have been able to find out, I think each hole is worth 1mm so the max setting I have on the rear bar would be equal to a 34mm bar. Does that sound right? Since I do not want to take off the front bar and go with a smaller one, what kind of changes can I make to gain back the bias Justice Pete recommended? Changes to the front and rear tire pressures? More negative camber setting to the front end alignment? Thanks. |
01-16-2020, 12:22 PM | #2 |
Instagram: Sangstah
Is there a reason why you dont want to change the front sway bar setup? I'm running 27mm front and 32mm rear Pedders sway bars and the setup is amazing, it handles perfect. Making the rear stiffer may help but the ride quality is going to suffer for sure.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-16-2020, 12:53 PM | #3 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Nothing you can do except change to a softer front bar. The most you want on a front bar is a 27 mm solid bar. Which is fine for stock or drop springs. Your front 32mm hollow bar is like a 29 solid. Way to big for any rear bar. You rear bar is more like only a 30.5 solid on the stiff setting, or something close to that. There is a lot of factors affecting a bars actual rate or size, not all are the same size for size.SSEssence has it right for the street with his bars as to bias.
01-16-2020, 02:32 PM | #4 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
I honestly don't think you have much choice. What size tires are you running front & back? If you are running staggered, running a square setup helps, but won't make up for 0mm bias. If you are already running square and experiencing understeer you'll definitely have to swap to a smaller front sway. I run BMR adjustable 29mm front, 32mm rear sways with a square tire setup. Both on center holes gives me balanced handling.
01-16-2020, 11:35 PM | #5 | |
Banned
Also, I do like how it improved the front end lean when going around turns at speed compared to the smaller stock bar. However, I do know that when it comes to handling, having it super stiff in turns is usually not the best way for handling balance. I have the rear bar on the stiffest setting, but I honestly can't tell of a big difference between the middle setting the stiffest setting. It feels the same to me. The only resaon I did that was to gain back some of the front to rear sway bar bias that was recommended. |
01-16-2020, 11:47 PM | #6 | |
01-17-2020, 12:14 AM | #7 |
Banned
I remember another member on here having the same setup in bars, 32mm Hotchkis hollow front and rear sway bars, and he mentioned that dialing in more negative front camber helped with increasing the handling balance that the lack in sway bar bias gave him.
In other words, he was able to use the sway bars he already had and made camber adjustments to the front suspension alignment to gain the front tire grip back as needed. I would like to try this approach if possible. The car does handle great in turns and there is virtually no lean. Even with the Stabilitrac on, I can induce throttle controlled understeer/oversteer at will. However, I know my max grip has probably been compromised due to the lack in bar bias that is recommended. |
01-17-2020, 12:28 AM | #8 | |
Banned
I'm also debating whether to invest the money in one of those DIY setups where you can do the alignments yourself. The newest versions have a self-leveling feature that make it easier to do in a normal house garage. |
01-17-2020, 12:29 AM | #9 | |
It helps, but proper bars are way you do it. Seems Hotchkis bars better for high horsepower where you don’t want a big rear bar as the bigger bar and the power can make the rear slide out if gassing it in a turn. |
01-17-2020, 02:06 AM | #10 | |
Banned
01-17-2020, 05:57 AM | #11 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Man I hate to say it you just might have to bite the bullet, if you want it to handle better just find a 1LE front bar an be done. I swapped bars twice before finally finding a front 1LE bar an a JPSS 32mm rear bar handles great!!
An sell your current bar somebody will want it for street driving.
Orange Krush II
01-17-2020, 11:14 AM | #12 | |
Also what size tires and wheels do you have? If staggered stock sizes that makes understeer even worse. As I said, and best I could come up with with Hotchiss stiffness data and swaybar calculators your rear bar is close to a solid 28,29 and 30 mm solid bar for holes 1,2 and 3. Try getting a factory front 25mm bar from a zl1. It’s not expensive and has 40 % plus stiffer then the stock 23 mm bar. That way you can adjust the rear and dial in what you want. It will still roll some but not bad, and if you have stock tires some of the roll is coming from them also |
01-17-2020, 12:46 PM | #13 | |
Banned
01-17-2020, 01:09 PM | #14 | |
Banned
If 5 mm or so is the magic number for almost perfect balance, then all I have to do is gain a mere 2 mm somewhere. Of course, I realize it's more than just pure numbers and there is a lot more at play here. I thought about varying the front to rear tire pressures. It seems from what I've read about the subject in the autocross forums, increasing the front tire pressure relative to the rear will decrease understeer and provide more grip for the front end. However, I don't know what tire pressures to begin at to notice a difference in handling. 28 psi front vs 35 psi rear? 32 psi front vs 35 psi rear? Ultimately, I guess I will have to experiment to see what the car likes best. |
Thread Tools | |
