Old 01-30-2022, 05:45 PM   #1
2010BlackCamaroSS
2010BlackCamaroSS's Avatar
Drives: 2010 Camaro 2SS/RS - L99
3.91 Gear Whine During Deceleration
I've got about 100 miles on the new AAM 3.91 gears and I am experiencing some gear whine that happens consistently from 48 mph to 40 mph. No whine at any other speeds during acceleration or deceleration.
I'm looking for some experts to chime in. Should I be worried?
Thanks, guys.
2010BlackCamaroSS is offline   Reply With Quote
Old 01-31-2022, 02:49 PM   #2
SaReNi
Drives: 2012 SS
who did the job?
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 02-06-2022, 08:01 PM   #3
oldman14ss
Drives: 2014 1ss camaro
don't want to be the bearer of bad news. they shouldn't whine no matter what speed or milage on them. its not the gears it was the install. poor install cost me 1500 bucks and a new set of gears I have AAM 3:70 gears on a Detroit tru trac. first install sounded just like yours. was going to take mine back to the same dude but why? so he could screw it up again. I apologize but I think you have problems. I hope you don't I went 1 gear oil change and 2000 miles and all it did was get worse. took it to a guy nwho knew what he was doing no whine straight out of the box 10k miles still no noise what so ever
oldman14ss is offline   Reply With Quote
Old 02-06-2022, 09:48 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Yep. Noise = improper install. Gears are helical cut to avoid noises, so any noise means it's too late.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 02-07-2022, 01:08 AM   #5
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
Sounds like backlash or bearing preload wasn't done properly. Bearing Preload is the one most people neglect. If the preload isn't right it will cause the gears to shift which will then cause improper set-up and create noise. I'd take it to someone and have them double check everything.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 02-10-2022, 08:04 PM   #6
oldman14ss
tolerance on my pinion was so tight that it didn't need shims.
Old 02-11-2022, 07:24 PM   #7
2010BlackCamaroSS
Thanks for all the replies, fellas. I know I have read several times that they shouldn't make noise. If it makes a difference, I did upgrade the diff bushings and installed an LPW cover. I hear that can increase NVH.
I knew the 1st shop I took the gears to did a horrible install job; it was clear from the gear pattern and the ratcheting sound the diff made when rotating the pinion. Luckily, they admitted they couldn't do the job properly and didn't charge me any money. However, they gouged up my case pretty bad, so I'm going to have to bill them for the damage.
I decided I didn't want to take a chance on another shop that I didn't know anything about, so, for piece of mind, I took it to a shop that has a great reputation on this site. If they can't get it right, I don't know what else to do.
I have been babying the gears (which is excruciating) so that they are broken in properly, but it sounds like I've been wasting my time.
