03-02-2017, 11:42 AM | #1 |
What mods have you done to lighten your SS?
Any ideas?
03-02-2017, 11:54 AM | #2 |
Instagram: Sangstah
carbon fiber hood/trunk lid would shave some pounds, maybe delete the rear seats.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-02-2017, 11:55 AM | #3 |
USA-1
Muffler delete will save about 20 pounds. Longtubes will save some weight as well.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
03-02-2017, 12:13 PM | #4 |
Drives: 2010 SS Join Date: Jan 2017
Carbon Fiber Drive Shaft
03-02-2017, 12:18 PM | #5 |
Drives: Camaro Justice Join Date: Jun 2007
Start cutting...
The rear deck lid is heavy so CF saves weight. The hood is aluminum. A CF hood is about the same weight. |
03-02-2017, 12:20 PM | #6 |
Add horsepower.....it's easier than shedding weight, LOL.
-Scott |
03-02-2017, 12:28 PM | #7 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
LT headers and chambered exhaust. Weighs less than the stock exhaust and added hp. Have plans to replace all panels possible with carbon fiber panels but that will be awhile.
03-02-2017, 12:45 PM | #8 |
Drives: 2011 ss Join Date: Sep 2015
Wheels and diet
03-02-2017, 12:51 PM | #9 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Battery.
03-02-2017, 01:00 PM | #10 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
6 tacos instead of a dozen.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
03-02-2017, 01:21 PM | #11 |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
Removing the airbags saves about 50 pounds.
2018 ZL1 2015 1SS 1LE Stock...ish |
03-02-2017, 01:32 PM | #12 |
Drives: 2015 2SS/RS 1LE G7C, Join Date: Nov 2015
Sucked the window washer fluid out, well left just a bit. But I have no intention on driving in a shower of any amount. Easy few pounds.
03-02-2017, 01:32 PM | #13 |
Love me some Tacos
Go on a diet and remove all passenger seats. Remove carpet, AC Unit, OEM Exhaust... Replace Wheels, any un-sprung weight. Or trade in current car for 2017 and then apply same...
03-02-2017, 03:13 PM | #14 |
Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
I think it would be easier to have a good Bowel movement that would result in the same weight reduction. As far as the window washer fluid, leave it in. One, you never know when you might need it (Bird decides to have a BM over your windshield) and TWO, if you go to use it and it's dry, there goes your washer motor pump.
