11-26-2022, 04:43 PM | #1 |
Drives: 2013 1ss Join Date: Jul 2012
tire wear issue
My car is wearing the right rear tire on the outside much more than the inside. I have had the car aligned and have checked the camber. The camber on both sides measures .2 negative but the right tire wears as if it is positive camber.
Suspension is upgraded BMR arms with viking adjustable coilovers. Ride height left vs right is within 1/16. This has happened on two different tires and wheels and only on right side. The inside wear mark on the tire is not to wear mark, mid is at wear mark and outside is worn into wear mark on both sets of tires. The only thing I find different when measuring multiple areas left vs right is there is about .8 degrees difference of the left axle vs right. Everything else matches left vs right. Anyone else run into this? |
