01-12-2014, 03:54 PM | #1 |
Drives: SS Join Date: Jan 2014
What suspension upgrade to do next?
About to get an ECS KIT installed on my L99. And also most likely doing a cam and meth while I'm at it. What suspension upgrades should I do next? Right now only have BMR drop springs. Also on the fence on going with pfdat or bmr.
01-12-2014, 04:08 PM | #2 |
You will want to make a few rear end upgrades to help you put your power to use. I would put rear cradle bushings and rear trailing arms high on the list. Toe rods and sway bars would be just behind those two.
01-12-2014, 06:33 PM | #3 |
Pfdat or bmr?
01-12-2014, 07:51 PM | #4 |
The Man in Black
Drives: 1969 Camaro 2010 Camaro 1SS Join Date: Apr 2009
I'm very happy with my pfadt parts
01-13-2014, 01:16 PM | #5 | |
Drives: pleather and Chiclets Join Date: Mar 2012
dont know your goals, how you drive, where you drive, what you expect in your drive, how often you drive... pretty crucial info seems with such a big power upgrade you would need some substantial upgrades in traction and strength throughout
01-13-2014, 02:16 PM | #6 |
01-13-2014, 02:36 PM | #7 |
This is a street car. Most likely will never hit the strip. I drive the car pretty hard honestly I don't baby it.
01-14-2014, 04:40 PM | #8 |
Drives: Race Car Join Date: Sep 2009
There are a few directions you could go. I would look at a set of trailing arms (TCA026, TCA027, or TCA033) and outer trailing arms bushings (BK006) which will help with wheel hop and overall performance. Rear cradle bushings (BK016, BK024, BK027, or BK040) are never a bad idea no matter what you are wanting to do because it will help get rid of the unwanted movement in the rear of the car. The last option I would look at is picking up a set of our BMR sway bars (SB030, SB037, or SB039) which will vastly improve the handling on your vehicle and give it a much more responsive and balanced feel.
01-15-2014, 10:33 AM | #9 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
My car is a daily driver as well.
Rear cradle bushings would be #1 on the list. I have Pedders inserts, but am looking to upgrade to solid bushings (pfadt or ADM Performance). I love my Pfadt sport sways and endlinks. I have also upgraded a couple other bushings, and the car handles like a dream. Trailing arms/toe rods are on the wish list, and will become a "must have" once I upgrade to an aftermarket cam.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
01-15-2014, 09:13 PM | #10 |
Drives: His Wife Crazy Join Date: Jan 2008
How do you plan on using the car, daily driver, weekend car, mostly track use, etc.
How do you drive the car, hard onthe gas, easy on the turns, etc. What is your experience level with performance driving, experience level at the strip, experience level at the autox/road course, etc. What size tires are you going to be running front and rear What does it not do as well as you would like, i'll do what i can to point you in the right direction. |
