Old 07-21-2015, 11:04 PM   #1
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
Not another cam question...
Before I pull the trigger on a cam.. I need some valued opinions from the experts... I'm indecisive on which bump stick I wanna run... I've done the research on cams and what not. I hear NF makes big power but drivability is an issue.. The BTR stage 2 makes good low end and mid-range. Haven't heard to much about the LG G6x3.. I really don't drive to much in the upper RPMs unless duty calls. I can sacrifice the low end due to have a 1LE and the gearing to keep it drivable at low end. I've read the horror stories about comp cam based grinds. Does anyone know if the BTR is a CC grind or the G6x3 is one as well. I know NF is a cam motion grind. All opinions wanted. TIA
If you're reading this objects In side view mirrors are losing as I'm rowing the 3:91's
1Slow6.2 is offline   Reply With Quote
Old 07-22-2015, 12:12 AM   #2
SrtWtF
SrtWtF's Avatar
Drives: Nsrt & Camaro SS
Gpi SS1 or SS2
SrtWtF is offline   Reply With Quote
Old 07-22-2015, 12:38 AM   #3
Bodywerks
Drives: 2015 2SS/RS/1LE
Actually, our final drive ratios are only taller in 1st and 4th. We a shorter(read, less bottom end final drive torque) in 2nd and 3rd and nearly identical in the overdrives.
So you really don't want to sacrifice too much low end at the crank.
All the cams you mentioned are pretty much top end, seat-of-the-pants cams, except maybe the BTR stage 2 cam It might be better for overall driveability and plenty of pick-up in the midrange and up top. I haven't talked to Brian personally, but I have only heard good things about him and he can surely fix you up. Also talk to Kip at cam motion. I prefer cam motion cores personally.
You can also spec your own cam. Lots of options here. You really just have to read up. Also, if you plan to have someone else do the work, they will likely be able to give you ideas.
I almost went with a TSP 235/239 but, like you, wanted a little more bottom end grunt, So Pat G spec'd me a cam for my exact setup and and overall desires and came up wit a slightly taller intake but over a shorter duration and a slightly shorter exhaust but over a longer duration, as well as 2 degrees of cam advance. This should give me more grunt in the lower(like 2800-4,000 range) without completely laying over up top.
Cam for cam, the tsp would probably win slightly in peak hp and in the 1/4 mile, but from a roll or on a twisty track, my custom cam may have an advantage.
We'll find out soon enough! Cam gets here tomorrow, heads in a week or so(hopefully), and all other parts have been trickling in since yesterday...
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 07-22-2015, 04:38 AM   #4
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
For what it's worth, a coworker of mine has a '12 LS3 Camaro that just so happened to have a Nightfury in it. I was interested to see what the drivability was so, he brought the car in for me to take around the block and get a feel for it. Having owned a cammed car in the past, I know how unruly these things can get so, this was good insight. I drove the car on base so the speed limit is awfully low but, not once did the car buck, show any signs of hesitation or anything else that would take away from the driving experience. Mind you, he had the cam installed and tuned by Lethal themselves.
2018 Audi TT RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped).
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
2021 Charger Hellcat Redeye Widebody
Sold
USAFS197 is offline   Reply With Quote
Old 07-22-2015, 05:10 AM   #5
Bodywerks
True, I have never heard of drivability being an 'issue' with the majority of more popular 'off-the-shelf' cams, even the more aggressive ones. Maybe not as much fun in a parking lot or stop and go traffic, but that's just a very small trade-off for the fun factor of a cammed car...
2015 SS/RS/1LE
Old 07-22-2015, 06:20 AM   #6
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
I challenge your claim of drivability issues with the Night Fury cam as untrue, if tuned properly it will drive normal.
Fred 6528 is offline   Reply With Quote
Old 07-22-2015, 01:52 PM   #7
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
No drivability issues with my NightFury at all.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap|
Built by J-Rod.
Taco Time is offline   Reply With Quote
Old 07-22-2015, 01:57 PM   #8
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
JRE 480 is a nice cam, drives out great.
Bye bye, Bumblebee!
Old 07-22-2015, 02:17 PM   #9
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks for the recommendation Stych9.
I have a full line of cams to choose form to fit your specific needs, feel free to give me a call and I will fit you with the right cam, that's what we do.
I can also provide the custom tuning to go along with it to make it drive like a dream and work to full potential.
Thank you
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-22-2015, 03:08 PM   #10
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
With 3.91's you shouldnt have an issue. My pat g cam specs are kinda close to NF but more overlap and I have a 112LSA and not 113 like nightfury. My car is my daily driver and I have no complaints on drivability with 3.91's
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 07-23-2015, 02:10 PM   #11
avido
Drives: camaro ss\rs
i use NF in my daily,there is a issues just around 1200rpm
avido is offline   Reply With Quote
Old 07-23-2015, 02:53 PM   #12
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
I have the NF in an auto, and have bucking in 5th-6th below 2k rpm. It can be aggravating, but not awful. Granted, it may be diff in a manual car, or a car with a diff stall than me.
Old 07-23-2015, 06:21 PM   #13
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
there is a lot in the drivability to the LSA of the cam, the tighter the more higher you need to take off in gear in RPMs and the higher the idle.... Anyway there a good article in the differences LSA make by comp cam as far as broadening the power band, vacuum etc etc loss of h.p...... You can get grind of whatever spec you want by cam motion, the thing is most do not show the NF's spec which is like .616 lift etc and fairly good duration to help its LSA which can be adjusted, the G6x is very tight PTV clearance..... And cam motion makes cams with various cores. I have not heard comp trashing lately, yet know people will blame what ever and not do a break in on the cam, or use good oil.....
I know my TSP .235/.239 speced out more than the nightfury and it liked it above 1400 rpm as its tight 112 LSA was not the most street friendly but made good power on the dyno.....
Old 07-24-2015, 02:37 AM   #14
Bodywerks
If he were running 3.91's on a SS, I would agree, but 3.91's on a 1LE(which is what the OP has) are ZERO advantage unless you're on a twisty track. The car will actually lug MORE than even a stock camaroSS in 2nd and 3rd gear.
Camaro ss with 3.91's, different story...
2015 SS/RS/1LE
