09-21-2018, 05:53 AM | #1 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
OMG MPG
There was some talk on a thread a while back regarding MPGs and there were numbers flying around everywhere. So, I thought it would be great to start a thread proving our stats.
Calculating mine was easy because it rolled over to 30k miles at the gas pump. So, I filled her up.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
09-21-2018, 05:56 AM | #2 |
After two weeks of driving and 98 miles later, I was back at the same pump, filling her up again.
09-21-2018, 05:58 AM | #3 |
And here are the results. Now, I'm no math whiz, but I'd say those MPGs are not great, but in line with my horsepower. Don't believe I will be daily driving her anytime soon. LOL!
09-21-2018, 07:31 AM | #4 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
Wow! Going off your signature I'm guessing that's e85? It's great stuff, but I've always heard to take your mileage on pump gas and half it for e85. Probably a combination of being less power dense, but the extra power goading you into using it more
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
09-21-2018, 08:19 AM | #5 |
I get around 21hwy E85 and 26hwy 93. My 5th gen would get 19hwy/24 93
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
09-21-2018, 08:50 AM | #6 |
Yep, e85. I picked up about 75hp with the conversion.
09-21-2018, 08:52 AM | #7 |
You're NA, so I can see how the numbers could be closer together. At just under 7 mpg, not sure even 15 is possible for mine on the highway. Maybe 10.
09-21-2018, 01:21 PM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
looks like you got her dialed in
09-21-2018, 01:37 PM | #9 |
Boosted Moderator
I can't / won't prove it, since there is nothing to brag about....
I get about three if I'm lucky on the street, and about 5 gallons to the mile (GttM) on the track...... C16....
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
09-21-2018, 05:07 PM | #10 |
Gallons per mile. Now we’re talkin!
Anyone else sub 10?
09-21-2018, 05:21 PM | #11 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Does the '68 count?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
09-21-2018, 06:16 PM | #12 |
Boosted Moderator
09-21-2018, 10:29 PM | #13 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
My DIC said right at 10 the other day. That was all around town/driving the hell out of it though. I think I'd still get 20+ just cruising down the highway. Just hard to keep my foot off the floor
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
09-22-2018, 01:01 AM | #14 |
I get about 7-8 in town and 20 if I'm lucky on the freeway. Usually around 18.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
