Old 10-20-2013, 03:43 PM   #1
2011RS/SS
2011RS/SS's Avatar
Drives: 2016 corvette Z06
2014 Rear bumper problems???
Was at the dealer the other day and they got two brand new 2014
SS. I asked what was up with the license plate areas and they said the holes where you put on the license plate was not in the right areas.
I didn't think about it at the time, but wondering if somehow they got European specs rear bumper covers, because their license plates are longer and skinnier than ours
2016 A8 Z06
CAI,E85,lower pulley
650rwhp/720tq
2011RS/SS is offline   Reply With Quote
Old 10-20-2013, 03:50 PM   #2
Buffman
1LE FTW
Buffman's Avatar
Drives: 2014 Camaro 2SS/RS 1LE Recaros NPP
There is no problem, they just need to know what they are doing
Attaching the 2014 Camaro's Rear License Plate
The rear fascia of the 2014 Camaro has small dimples at various locations around the license plate area. These dimples provide an accurate reference for the mounting locations for various sized license plates, depending on the market where the car is sold.
During Pre-Delivery Inspection (PDI), it may appear that the license plate mounting holes should line up with the large rectangular holes in the rear fascia. This is not the case. Behind each of the rear fascia dimples (See image below) is a plastic boss.
Center the license plate on the rear fascia and confirm that a dimple is visible in each of the license plate mounting holes.
With the correct location confirmed, install the license plate using the self-tapping screws included in the PDI bag. It is not necessary to pre-drill the holes. The self-tapping screws will attach the license plate to the rear fascia.
Buffman is offline   Reply With Quote
Old 10-20-2013, 04:07 PM   #3
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
They could also use an old trick- put masking tape over the dimples, then get a plate, and stick a PENCIL THROUGH THE HOLES
This is not rocket surgery. You'd think anyone with the pluck of a weevil in a biscuit could figger this out
hell you'd figure a tech would have some sort of mechanical aptitude too
ChrisBlair is offline   Reply With Quote
Old 10-20-2013, 08:31 PM   #4
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
When I bought my 2014 they had to drill some holes for the license plate.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 10-20-2013, 11:10 PM   #5
fussboss
fussboss's Avatar
Drives: 2014 2LT RS
I would go to a different dealer from now on lol... wow.
fussboss is offline   Reply With Quote
Old 10-20-2013, 11:45 PM   #6
2011RS/SS
2011RS/SS's Avatar
wow.. I should have expected as much from a small town dealer
Old 10-21-2013, 01:56 AM   #7
CamaroBody
Drives: Hyper Blue 2SS
You have to drill holes in rear bumper? There are not four built-in female corners to screw in the license plate?
CamaroBody is offline   Reply With Quote
Old 10-21-2013, 06:29 AM   #8
Buffman
1LE FTW
Buffman's Avatar
No if people would look closer there is pre-made 'dimples' that the self tapping screws you get with the car work as intended.
Apparently different states have different holes for their license plates (as well as other countries, obviously) so this is actually a good thing.
Old 10-21-2013, 09:26 AM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Dealers are often dumb.
