08-13-2014, 11:38 AM | #1 |
Track > 1/4 Mile
Cutouts / Open Exhaust on Boosted Cars
Recently installed cutouts on my ZL1, primarily so I could wake the dead
However after talking to some people claiming that cutouts on a boosted car are bad and even some people saying that cutouts can damage valves I started reading up on all of this. It seems like the whole cutouts damage valves is a myth, unless you're running open exhaust right by the headers. However mine is installed right before the mufflers, so way in the back of the car. Also it seems like on N/A cars the loss of backpressure does not affect performance at all. In fact it helps it, here's a good article. This makes sense since I've seen dyno reports of slight gains with cutouts open. However I have yet to see any dyno reports of cutouts open on boosted cars, in particular supercharged vehicles. So I'm wondering if the cutouts are actually hurting performance on my ZL1? Thoughts?
08-13-2014, 01:18 PM | #2 |
Drives: 2012 SS Join Date: Sep 2012
I love my cut outs but when they are open it is so loud that it shakes the car and gives me false knock so I make signihantly less hp with them open
08-13-2014, 01:57 PM | #3 |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
On turbos they offer no restrictions and sound great. Since no restriction you can actually gain quite a bit of power.
2012 CTS-V: Cosmetic Chute. |
08-13-2014, 03:14 PM | #4 | ||
Track > 1/4 Mile
I know I must be making some serious back pressure at WOT. Two times now since I have gutted my cats I have blown my mid pipes off my "hollow cats." Both times it happened when I capped off my cutouts, never had the issue when I have them opened up. The first time I attributed it to maybe me not tightening the clamps enough, but then it happened again. I do not think my exhaust is clogged anywhere, I'm assuming it's happening now that that cats are gutted and the exhaust is more free flowing?
08-14-2014, 12:50 AM | #5 |
We have ran my car a couple of times on the dyno with and without diverters open (noweeds). No change in peak torque/hp - but that's with cats... Without cats I would expect gains to be minimal (at best)
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73) CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials |
08-14-2014, 09:05 AM | #6 |
Track > 1/4 Mile
I'm not expecting gains, I just want to make sure I'm not losing any power. I'll have to make an appointment sometime on the dyno and check for myself. When you ran it on the dyno do you remember if you lost any low end torque? That seems to be the concern with most people. Saying that with no back pressure you lose low end power / tq.
08-14-2014, 09:15 AM | #7 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
Yup i get false knock when i have my noweeds fully open and i have them installed right after the headers.
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
08-14-2014, 11:46 PM | #8 | |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Boost with cutouts is no problem . . . I am running 13 psi with meth injection auto start at 9 psi.
LOL, yes my son couldn't keep the note on the road cause I kept throwing him back in the seat.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
08-15-2014, 12:30 AM | #9 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
I just dyno'd yesterday and on the 2nd pull forgot to open exhaust controller. Made 720 on all 3 pulls.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
