![]() Drives: 2010 Black 2ss Chevy Camaro Join Date: Nov 2011
Quick coolant question
I was driving for about an hour and got the warning my coolant overheated and I needed to idle the engine. I checked my coolant reservoir and it was low.
I ended up having to stop at a 711 and add PEAK coolant 50/50 I understand I’m suppose to add dexcool but this is all they had. How bad is park? Do I need to flush my coolant? I ended up adding about 1 cup (not that much) could I just leave it? |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
I would flush it out, change the thermostat and use dexcool or compatible dexcool Prestone. When you refill, add from the radiator cap, the reservoir and from the top hose of the radiator right into the block, these cars a tough to get all the air out. See the link below for a thermostat replacement video.
![]() Drives: 13 Camaro Join Date: Oct 2016
You should have just added some distilled water to it. I would completely flush the cooling system. I would first find the leak you have. Leaks cause air to be mixed with dexcool and that will turn it to sludge. Coolant doesn't disappear without there being a leak.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
A cup low in the reservoir is nothing. Might be something else getting ready to happen.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
#6 |
![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
How about your cars,do you have to add coolant in reservoir ?
I have to add approx. 1-2 quart/year. |
#7 |
It don’t come easy.
Put in a shutoff valve and topped everything off. Been good for a couple years now.
