06-13-2021, 11:13 PM | #1 |
Drives: 2010 Camaro ss A6 "Chief" Join Date: Dec 2020
Spark plug help
I just put in some NGK tr6 spark plugs in my l99, before with the old acdelco plugs the car idled fine but now that i put the tr6's in it runs like crap, misfiring and drooping down to 250 rpm and sounds like it has a very crappy spec cam, I made sure that all the plugs were gapped to .040 like normal. any ideas?
06-14-2021, 06:36 AM | #2 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
You could of cracked a plug. I would remove them and inspect them
06-14-2021, 07:31 AM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
where did you get the spark plugs from? lots of fakes out there...
06-14-2021, 07:34 AM | #4 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
06-15-2021, 01:57 AM | #5 |
I just bought the plugs from amazon, quick shipping I checked all of my plug wires and they are all tight, so i will pull them all out and check if any are damaged.
06-15-2021, 06:30 AM | #6 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
There are several sites discussing counterfeit spark plugs on Amazon and how to tell the difference. That said I lucked out with the AC Delco I purchased there.
06-15-2021, 07:40 AM | #7 |
Drives: 2011 Camaro SS Join Date: Sep 2017
local parts store should have them in stock - oreillys, autozone
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
06-15-2021, 06:53 PM | #8 |
Yep, lots of "fake" plugs out there, gotta watch out and only purchase them from a reputable auto parts store or somewhere like Phastek.com... Plus the TR6's are for cammed applications..Not for stock engines. TR55's are what I had in mine with LT's and a CAI..And tuned..
