Old 10-30-2013, 10:40 AM   #1
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
SS differential swap
So... yeah. SS differential swap. What all do I need part wise? And/or is there a kit out for it (unlikely). I could use GM part numbers too (I don't know what I'm looking at when I'm searching on the gm part sites usually).
Thanks in advance.
Sent from my DROID Mini
DSX_Camaro is offline   Reply With Quote
Old 10-30-2013, 11:28 PM   #2
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
I've just gotten all my parts ordered for this swap. My garage people (not doing this one myself) found that all I need other than the differential carrier are new axles and hubs. From what others have said the drive shaft mates right up. I don't have part numbers, but this should give you an idea.
Note: because I'm a 2LS I have to buy a new carrier too
6bangerBOOM is offline   Reply With Quote
Old 10-31-2013, 01:55 PM   #3
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
For 2012 and up the drives shafts mate up. What about 2010 and 2011?
Old 10-31-2013, 05:43 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Scotty, that actually helps more than you realize. Thanks.
