11-25-2013, 06:49 PM | #1 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
V6 guys - manual transmission
Would it be possible to use the manual out of the Cadillac ATS? The Tremec TR-3160.
11-25-2013, 07:37 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
That would be awesome. The TR-3160 is 10% lighter and 10% stronger than the AY6. It's hard to compare the images on the internet to see if the bell housings are similar. GM Inside News said it was designed specifically for the Cadillac ATS. Maybe this will be the manual transmission for the new V6 6th Gens.
