05-22-2016, 10:18 PM | #1 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Rear SS Brakes
Pretty self explanatory... I have a 2LT/RS and want to know what goes in to converting the rear end to the SS quad piston calipers.
05-23-2016, 07:50 AM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
You'll need the calipers, rotors, and pads of course but think you'll need the dust shields for a SS car because they obviously different and brake line, after that it should be pretty straight forward.
Orange Krush II
05-30-2016, 12:28 PM | #3 |
Drives: 2015 Camaro 1LS Join Date: Oct 2015
You actually can use your original rear dust shields, but you'd have to trim the lip off since the new rotor is quite a bit bigger. And just so you know, there is a difference in bore size between the v6 and v8 master cylinder, probably won't make a huge difference, but it's something to think about.
05-31-2016, 04:40 AM | #4 | |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Right on the money. Trim the lip about 1/4" and its golden. THen get hoses (Stainless steel braided preferred). As for the MC, when i did the conversion, i stuck with the V6 MC at first. It just didnt feel firm like i had hoped. Swapped over to the SS MC...boom. There we go. Perfect braking now.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
05-31-2016, 11:06 AM | #5 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I have a set of rear SS brakes, been off the car for a while. PM me.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
