Old 03-28-2013, 04:29 PM   #1
TriGun
TriGun's Avatar
Drives: Camaro 2SS/RS Ice Silver
Magnacharger jackshaft bearing problem
Hello To All
I have 2010 Camaro L99 with MagnaCharger TVS2300. When my car was on dyno a loud noise with smoke came from the front of the supercharger shaft. immediately the engine was shut down and we found the bearing (indicated with the yellow arrow) was rubbing with the hub (indicated with the green arrow).
Now we are trying to remove the pulley carriage (indicated with the red arrow) in order to get the bearing replaced but we couldn't. I hope somebody can help with the following:
  1. How to remove the pulley carriage (indicated with the red arrow) ? we already tried to rotate it but with no success. Do we pull it with a pulley puller ?
  2. How to remove the bearing (indicated with yellow arrow) ?
  3. Are replacement parts available for the pulley carriage, hub and bearing ? (As shown on the attached picture)
Sorry if I misnamed the parts and for the picture quality
TriGun is offline   Reply With Quote
Old 03-28-2013, 08:22 PM   #2
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
I would call Magnuson. That should be covered under warranty.
ITGuy11 is offline   Reply With Quote
Old 03-28-2013, 09:39 PM   #3
carfansince73
carfansince73's Avatar
Drives: Carefully
I had a grinding noise which I suspected was a bearing issue in about the same area. I sent them a video clip of the sound. They asked me to send the s/c back and they sent it right back no questions asked and no money out of my pocket. Great customer service.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; MGW short shifter; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!!
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline   Reply With Quote
Old 03-28-2013, 09:47 PM   #4
motorhead
I read yesterday that they had some problems in that area on earlier models. I would call them.
Old 03-29-2013, 03:05 AM   #5
TriGun
TriGun's Avatar
I already sent them an email and waiting for the reply.
I'm located in Kuwait, I don't think sending the unit to them is feasible. Sending the replacement parts with instruction is more practical and feasible.
Old 03-29-2013, 06:05 AM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
You need to send just the jackshaft. I have changed the 2 piece hubs on my TVS before with a pulley removal/3 jaw puller set but I wouldn't advise doing that with the jackshaft. I can track down the part number of the pulley if you need it.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 03-29-2013, 09:12 AM   #7
TriGun
TriGun's Avatar
Thank you for the help.
Ted@JannettyRacing just replied me with the same.
But what is the part number for the part indicated with the green arrow ? and what its name - is it called "hub" or "Carriage" - ?
Old 01-10-2014, 08:30 AM   #8
TriGun
TriGun's Avatar
For anybody may face the same problem. I ended up ordering a new jack shaft assembly from Magnouson with both carriage front and back. Using a pulley puller to remove the pulley carriage is not recommended as the force applied on the center can easily damage the carbon fiber shaft.
Old 01-10-2014, 01:24 PM   #9
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
What kind noise did you have? I'm getting a grinding/rattling noise somewhere under my hood that sporadically comes and goes, but can't pinpoint where it's coming from. It's most noticeable at idle and really getting on my nerve! I thought something on my exhaust might have come loose again, but everything there looks tight, so I'm lost on this one!
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 01-10-2014, 02:48 PM   #10
jvoisel
Drives: 2010 2SS/RS M6
I just had to replace my jackshaft bearings, it was almost a grinding sound.. I spun the jackshaft by hand with both belts off and it was pretty loud. Almost silent now with new bearings. I have a few vids of the noise, PM me your number if you want and I can send them.
Since I caught mine before the bearings let loose, I was able to just replace the bearings which would cost maybe $10 vs $500 for jackshaft/carriages. Make sure yours are right!
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 01-10-2014, 03:59 PM   #11
fldrummer
"Black Ace"
fldrummer's Avatar
PM sent... Was the noise constant or did it come and go?
Old 01-11-2014, 12:19 PM   #12
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
Mine made no noise until it completely failed. I did notice about 1000 miles before it failed that I had some oil/grease on the back of the manifold. I assumed it was some residual seepage from the seals as I had just up the boost to 10#. The leakage was actually the grease from the sealed jackshaft bearing coming out. After that happens its only a matter of time until it fails!
Sent the jackshaft assembly back and got a replacement no cost! BTW only had 6K miles on it. Hope it don't happen again!
Chevy69er is offline   Reply With Quote
Old 01-12-2014, 11:00 PM   #13
jvoisel
Constant, varied with rpm
2010 2SS/RS
Old 11-07-2016, 02:31 PM   #14
ktooker2010SS
Drives: 2010 Camaro SS 6.2 Magnuson TVS2300
2010 Camaro SS Mgnuson bearing problem
I have a 2010 Camaro SS with 6.2L L99 with the Magnuson TVS-2300 Blower setup. The front needle bearing is bad...making noise. Magnuson wants to sell me the entire rotor assembly for $700 to get this bearing. Does anybody know how I can get this bearing without spending $700??
Ken
ktooker2010SS is offline   Reply With Quote
