09-13-2016, 06:33 AM | #1 |
Drives: 2012 Camaro 1LS w/L99/TR6060 Join Date: Dec 2012
Rock hard clutch pedal help.
I have a rock solid clutch pedal.
Things I've tried: 1. Bleed clutch 2. Tick performance clutch line 3. New master cylinder **Rebled after new installs still rock hard. I have read on other forums of this happening, but no one has given a good descriptive issue or fix. Car drove ok before this happened. Any advise or information would be greatly appreciated. L99/TR6060 1LS swap in the making. |
09-13-2016, 03:45 PM | #2 |
What clutch?
Linked line somewhere?
09-13-2016, 05:54 PM | #3 |
Stock 1LE and whenever I bleed it I get a good pull of stream from the vacuum pump. The pedal is just rock hard. New line and master.
09-24-2016, 09:11 AM | #4 |
She's done... L99/TR6060 1LS swap in the making. |
09-26-2016, 07:55 PM | #5 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
Replace the black plastic part with an billet aluminum one from Monster
http://monsterclutches.com/gen-5-cam...earing-support
U.S. Army Retired |
09-26-2016, 08:08 PM | #6 | |
I have to replace the entire thing haha. But I'm definitely replacing the bearing before I put it back together Sent from my iPhone using Tapatalk |
10-01-2016, 04:28 AM | #7 | |
Just asking but how come its aluminum instead of steel? Sent from my iPhone using Tapatalk |
10-02-2016, 10:13 AM | #8 |
Not sure. The factory part is plastic and is a known weak part of the clutch assembly. Monster makes theirs from aluminum and it holds up really well. Not sure if anyone makes a steel one.
U.S. Army Retired |
10-02-2016, 05:43 PM | #9 | |
Quartermaster USA makes a steel one. Thats the only reason I asked. Sent from my iPhone using Tapatalk |
10-02-2016, 05:48 PM | #10 |
Oh cool. I didn't know a steel one was made. Thanks for the info.
U.S. Army Retired |
