Old 02-19-2018, 10:19 AM   #1
WoodBoss
"Old School"
Drives: 2010 2SS L99
JRE Dipstick Installation Overview
I thought it was time to install a dipstick on the automatic transmission. Not knowing the exact level of transmission fluid in an automatic can be a bad thing especially on hard launches at the dragstrip. I made a short viseo of what I did to install the dipstick.
WoodBoss is offline   Reply With Quote
Old 02-19-2018, 12:30 PM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
I just did this a few days ago. Not sure if you mentioned it in the vid, but that bolt is a 15mm.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-20-2018, 08:33 PM   #3
W.E.G.
breaker of things
Drives: 2011 SS and 1988 Sport Coupe
I would be interested to see where the fluid level registers on the dipstick at various temperatures.
The Helm manual instructs that "correct" level is obtained when the fluid stops running out of the level-check straw-hole
at the prescribed temperature (which is neither cold or full-hot).
W.E.G. is offline   Reply With Quote
Old 02-26-2018, 11:57 AM   #4
WoodBoss
"Old School"
After adding an extra quart, when the car is hot and running in Neutral, my level was right at the top of the cross hatch area. The cross hatch area on the dipstick says "Hot" BTW.
Old 02-26-2018, 03:41 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Thanks for info!
Old 09-06-2018, 09:06 PM   #6
InfernoB
Drives: Camaro 2SS RS L99 Blk with IOM pkg.
Any idea what "hot and running in Neutral" refers to specifically, concerning the actual temperature of the fluid? Thanks!
InfernoB is offline   Reply With Quote
Old 01-07-2019, 04:44 AM   #7
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
So running in neutral and hot is the proper way to check fluid level with the JRE dip stick?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 01-15-2019, 08:35 AM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
I would be leary of the markings on the dipstick. Unless you leaked atf, you should still be at the factory fill level. I wouldn't think you burned off any atf. The only way to really know is to drain it and replace with the recommended capacity or pull the fill plug, then check the installed dipstick. Idk if 1qt over capacity would be harmful to the auto, too much can be.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 01-20-2019, 07:17 PM   #9
John_C
LSx FTW!!!
John_C's Avatar
I replaced the speed sensors and did a fluid and filter change. Did the JRE dip stick at the same time.
So I have no baseline.
HP Tuners VCM Suite
Old 09-18-2022, 01:45 AM   #10
kwikbowtie
Drives: 87 Monte SS, 68 Chevelle SS, Camaro
temp of fluid when checking level with JRE dipstick
Does the fluid need to be between 86-122 F when checking the level on the JRE dipstick? If you add the extra quart to get to the top of the "Hot" hatch marks what is the temp of the fluid with the tranny in park to check level?
kwikbowtie is offline   Reply With Quote
