10-20-2015, 02:48 PM | #1 | |
Drives: Want a gen 6 Join Date: Jan 2013
Does this tune only Auto c7 1/4 mile time relate to the g6 A8?
If anything? I'm thinking the A8 Camaro could be 3/10's behind after a tune, am I off base?
10-20-2015, 08:02 PM | #2 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
A good tune on an auto is worth about 3-4 tenths on average.
...also, a when I see G6 I think Pontiac. Let's stick with gen 6 or 6th gen. ;-) |
10-20-2015, 09:44 PM | #3 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
I think we can expect the same results. It is fairly clear GM is under pinning this car in HP and torque.
10-20-2015, 09:52 PM | #4 |
I bet top speed is around 175 or 180 without the limiter too.
10-20-2015, 10:53 PM | #5 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
nice mph
The bone stock on stock tire stingray record is at 11.3 I believe. |
10-29-2015, 03:11 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
Dont forget this is a hero and record run. just look at some boltons C7 fast list; not so many reached this 'stock' mph.
But yeah an agressive full custom tune should yeld good result! CAI and tune with auto is gonna be an easy 11sec car I think.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-03-2015, 09:47 AM | #7 |
Drives: 2015 Stingray (on order) Join Date: Jan 2015
I can't see the video at work but I have a Stingray and spend a lot of time on the C7 forum and I would think 6th gens are gonna run high 11's bone stock. I ran 11.52 in my car bone stock in cool air.
What tires are they going to put on 6th gens? I know the PSS are amazing on my car, if the camaro tires aren't as sticky it may hurt them a little. If you want to go fast in the 1/4, buy an auto. |
11-11-2015, 08:36 PM | #8 |
Drives: CTS-V Join Date: Aug 2008
I've seen a stingray A8 cai tune and DR on stock wheels in +1300 da 68° = 11.4@120 with 1.7 60' Oct 15 Fayetteville.
Same car + E85 new tune ran 11.2@124mph 1.7 60' in -400 da 56°.
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
12-09-2015, 09:24 AM | #9 |
Does the gen 6 SS get the same fuel pump as the stingray?
Without forced induction would the gen 6 setup benefit from a dual pump system at all? |
