06-16-2021, 04:39 PM | #1 |
Rear sway bar link part number?
Im looking for rear sway bar link part numbers and everything that I find is not the right part. Does anyone have the part number for this rear sway bar link? I need the part number for the bolt, too. The bushings wore out and ruined one of the bolts.
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
06-17-2021, 07:42 AM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
06-17-2021, 01:03 PM | #3 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
I have the rear sway bar if you need it.
06-17-2021, 01:33 PM | #4 |
Damn, I knew the 2012-2015 model years had a different sway, link, and LCA, but I had no idea it was the type of design.
That end link looks beefy as hell compared to the 2010-2011 pencil thin ones.
06-17-2021, 01:39 PM | #5 | |
06-17-2021, 01:41 PM | #6 |
35,000 miles and the bushings just deteriorated. I’m guessing the Texas heat had their way with them. The sleeves are plastic.
06-17-2021, 01:55 PM | #7 |
Ohhh ok, so that thick outer shaft I am seeing is actually a plastic sleeve? Makes sense once I look at the top part where those ribs are.
Oh yeah I'm sure it was the heat mainly.
06-17-2021, 02:28 PM | #8 |
06-17-2021, 05:47 PM | #9 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Moog has a rear swaybar link that I think is better than stock. Instead of a plastic sleeve over the bolt it has an aluminum hex bar. Looks like it would have less flex than the stock link.
Only place I found them was rockauto. https://www.rockauto.com/en/moreinfo...t=7580&jsn=469 They are also cheaper than stock. Win/Win for me. Good luck Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
06-17-2021, 09:10 PM | #10 | |
06-18-2021, 06:21 PM | #11 |
It went fine. It is easiest with someone to do one side while you do the other, but one person can di it easily.
