Go fast, please.
Installing Z/28 spoiler
Just got the stock spoiler off my '14 ZL1 to exchange for a carbon fiber Z/28 spoiler and of course I have the rubbed off paint issue on the sides but I'll deal with that... My question is, what do I use to stop water from coming in these bolt holes? Are rubber washers enough? What did you guys do?
![]() Drives: 2017 1ss 1le Join Date: Sep 2015
use some rtv gasket maker to fill the holes. Problem solved
![]() Drives: 2012 ZL1 Join Date: Apr 2015
Back in the day when I had a grand prix GTP I use to use garden hose washers with dielectric grease between the spoiler and trunk lid. Never had a leak after that. Only thing is after a few years they dry out, however they're cheap and easy to replace.
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I used clear silicone
UPSTATE C5 MEMBER
Go fast, please.
#6 |
![]() Drives: 13 ZL1, 10 Silverado LTZ, Chopper Join Date: Oct 2011
You can use Marine Goop which works awesome for sealing anything. I'd make some plastic discs or something and put the Goop on the disc and place over the hole.
#7 |
I just put a good size dab on each of the unused holes and just a ring around the holes being used, then the spoiler will push down on it when installed and should seal up pretty good
UPSTATE C5 MEMBER
#8 | |
Go fast, please.
