10-25-2017, 04:24 AM | #1 |
Drives: 2010 camaro ss Join Date: Aug 2017
Headlights
The headlights on my 2010 camaro are woeful!
Anyone upgraded bulbs/lights with decent success? |
10-25-2017, 03:24 PM | #2 |
http://www.ebay.co.uk/itm/Ultra-H13-...wAAOxyzqdTcfHw Something like this may help
10-26-2017, 03:25 AM | #3 |
Drives: 2010 Camaro SS Join Date: Oct 2017
My SS/RS HIDs are pretty awful too. I've read that the housings can suffer over time, and also the bulbs intensity can dimmer over the years too.
Plus I have a dim HALO on passenger side. So I either need a new passenger headlight, new bulbs, or I might just go aftermarket set. Annoying... :( |
10-26-2017, 02:31 PM | #4 |
I have a stock halo LED you can have, pm me if you like.
10-27-2017, 02:27 AM | #5 | |
redleader
Will those plug-in to Stock on my 2010 V6 LT without any additional harness? Cheers, James [redleader] |
10-27-2017, 08:53 AM | #6 | |
10-28-2017, 11:46 AM | #7 |
I just have the original from the RS HID lamp. They won't fit non HID. As I have all singing and dancing RGB I don't need them.
10-30-2017, 09:03 AM | #8 |
Including board? Will PM! Thanks!
I've also ordered 6000K HID bulbs, as mine are 7 years old and I suspect they are dying. Fingers crossed this improves them. If not, it's £70 for spares, but worth having anyway. GM ones were $120 each, but these from Diode Dynamics were cheaper, for a pair! https://www.diodedynamics.com/store/...-oem-hid-bulbs |
10-30-2017, 03:52 PM | #9 |
The LED sits on a hexagonal board. You will need to remove the bumper and headlamp. Then fiddle with a long thin torx screwdriver and get the old one out. Do a little wiring join and refit it all. Also check your headlamp aims, they could just be set to low. The HID's pretty good.
10-30-2017, 03:55 PM | #10 |
10-31-2017, 04:57 AM | #11 | |
Molehill Mike
2010 Camaro SS/RS |
