11-07-2019, 03:16 PM | #1 |
Drives: 2018 ZL1 1LE, 2014 ZL1 Join Date: Jul 2017
Things Are Getting Hot!!!
I melted another GM Part!!!!! (First being the engine wiring harness). Took the car in for upgraded brake lines and found this... cooked the coolant reservoir with my headers (coated for heat as well). Reservoir was completely empty and car has sat since track day in October so must have emptied on track or on way home.. shit happens. New one is getting heat shield..
2 inch headers from ARH.. Yall ever see this before? |
11-07-2019, 04:06 PM | #2 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Yikes!!! No, never seen that. I have the 2 inch ARH headers as well, been on for 8,000 miles. Just checked, no issue. Glad you caught it before any serious damage. The heat shield is a great idea.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
11-07-2019, 04:08 PM | #3 |
Drives: 2017 ZL1 Join Date: Jan 2017
Next time get them coated, Swaintech, I am running ARH also. I wasn't sure I wanted to spend the money on getting them coated but the entire engine bay is way cooler near the headers noticeably compared to other cars I've had with LT headers.
2017 Camaro ZL1 Coupe M6 (847whp Dynojet on 93)
11-07-2019, 04:09 PM | #4 |
11-07-2019, 08:14 PM | #5 |
Drives: gas powered Join Date: Jan 2019
Headers? yep everytime on everycar i every owned. I know the pros that sell them say otherwise.
11-08-2019, 08:18 AM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2018
I've never seen that, but I did unintentionally install the reservoir incorrectly when I did the headers (didn't line up the bottom tab correctly) and didn't notice it at first but did a few minutes later. It made the bottom of the tank stick out closer to the headers. Could this have maybe happened to you?
Also, was the bottom of the reservoir filled with coolant? These reservoirs are weird and just because the top is filled doesn't mean the bottom is and if it were empty in the bottom I can see the material overheating.
2018 ZL1 - Whipple with 3.25/9.10 pulleys, Katech 103mm TB, Rotofab Big Gulp Intake, Weapon X heat exchangers, 2" LT catless headers, AWE Resonated/Touring exhaust, NGK 6510 plugs, Granatelli 8mm Spark Plug Wires, 160* T-stat, Meth with dual 14GPH nozzles (running 100% meth), JMS voltage booster for LPFP - 806whp/808wtrq on 93
11-08-2019, 09:48 AM | #7 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Modifications of this type most always have some risk.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
11-09-2019, 09:01 AM | #8 |
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
2018 Z...20k miles (18k on build), 2 inch kooks, Ceramic coated, no cats...no heat issues whatsoever!
11-09-2019, 03:02 PM | #9 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Def not normal!
11-09-2019, 04:32 PM | #10 |
Drives: Camaro ZL1 A10 Join Date: Feb 2018
I kept melting starters on my C6Z from tracking with headers. Sad to see this happen on the ZL1 but this is another reason I track it stock to keep the warranty. If the shield works you could help many people in your situation.
11-11-2019, 09:11 AM | #11 |
Drives: 2017 Camaro ZL1 Join Date: May 2018
Does anyone know if the Moroso 63813 Coolant Expansion Tank will fit as a replacement to the factory plastic tanks? I just had headers put on mine and don't want to risk having this happen.
11-11-2019, 09:18 AM | #12 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
This thread has inspired me to buy some heat tape when I pull the trigger on headers in the coming months.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
11-13-2019, 09:28 AM | #13 |
Yep it happened after a heavy track day, I do not believe this would be an issue for daily driving at all.
11-13-2019, 09:58 AM | #14 |
Drives: Chevy Camaro Join Date: Jul 2019
Coated headers still get hot enough to melt things, they are not a unicorn for zero heat. Put your hand on a non coated header up to temp, then a coated header up to temp, it they will both burn the crap outta your hand, same with plastic.
Tags |
coolant, engine, headers, hot, melt |
