Old 11-20-2018, 04:27 PM   #1
Harry16
Drives: 2010 rs
Something leaked today HELP!
Something leaked from my car today, from the front.
It has a light blue color. Also a few days before the leak i had a check engine light pop up? Car is driving fine with no messages bieng shown on the dash. Someone help please!!
Picture is in the link
https://m.imgur.com/gallery/AEbrSO5
Harry16 is offline   Reply With Quote
Old 11-20-2018, 04:34 PM   #2
Harry16
Drives: 2010 rs
Old 11-20-2018, 04:36 PM   #3
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
Blue, huh? Are you a short drive away from any parts store so they can read the code?
It honestly looks like washer fluid to me... But I don't see that tripping the CEL.
Old 11-20-2018, 04:38 PM   #4
Harry16
Drives: 2010 rs
Yes i can get it read next week, not sure what leaked. But when i startrd the car i can hear something like water drops on the inside but not anymore?
Old 11-20-2018, 04:38 PM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
lol that's windshield washer fluid. maybe your reservoir cracked. no clue on the cel bro, do you have a scanner? if not head over to a auto parts store and have them scan it.
good luck!
peace
Old 11-20-2018, 04:40 PM   #6
Overflow
Overflow's Avatar
good luck!
peace
That's the only part that has me confused. I don't think low washer fluid trips the CEL. Unless he has bad luck and something else is tripping it.
Old 11-20-2018, 05:31 PM   #7
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Cold weather plus standard climate washer fluid equals something froze and cracked maybe. Wouldn't set a CEL though
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 11-20-2018, 05:45 PM   #8
Harry16
Drives: 2010 rs
Yes it was -20 outside when i started it. And yes it did have standard fluid.
Old 11-20-2018, 08:15 PM   #9
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Washer fluid=blue. Trans fluid=red antifreeze= green oil=dark brown/black brake fluid=light brown. Tuh duh!
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 11-21-2018, 07:46 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You most likely just flashed some warning code one that said install new washer reservoir yours is cracked, or overfilled...(Sarcasm)….and BTW your Engaging traction control and stabillitrac sliding in the snow...… I get TC warnings all the time, winter is hard on stuff and only worse in snow getting any traction and most likely why something popped up, and hopefully not something serious or it would have a constant CEL on the dash and you would have to read the code before clearing or unplugging the battery/replug….
Anyway check your reservoir and if cracked maybe a junk yard has one or gmpartsdirect.com or some good old two part epoxy putty etc....can fix you up and replace the fluid by emptying the reservoir and replacing with 100% good cold weather fluid good to lower than -15 degree fluid...… and the sound of the running water was most likely the sound of crap in the works of the a/c heater system with how cold it was just working its way out. good luck. I would avoid driving anything in temperatures that low if I could but a cold weather beater is not always a option; I realize so snow tires, and good fluids are a must along with jumper cables and a good battery I would recommend in your area especially. Good Luck.
Old 11-21-2018, 07:52 AM   #11
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
Washer fluid
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 11-21-2018, 08:22 AM   #12
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
actually our cars come with dex cool for coolant which is orange
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 11-21-2018, 08:29 AM   #13
Wizard1183
Wizard1183's Avatar
That’s right. Since the 90s I believe it went orange with the Dex. But I’m thinking old school. You can still put the green in it and no problems will occur. He’ll! Mid and match! Lol
Old 11-21-2018, 09:56 AM   #14
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
No you cannot. If you mix standard and Dex cool it will gel up and screw up your engine.
2014 2SS/RS LS3/M6
