01-29-2014, 03:41 PM | #1 |
Drives: 2013 Full Bolt on LFX M6 Join Date: Jan 2013
Need DIY for gen5 LS foglight conversion
I am awful with car electronics, and was wondering if anyone can post a walk through of installing the harness. I understand its just a plug and play, but a set of directions would be extremely helpful. Thanks!
01-29-2014, 03:47 PM | #2 | |
Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
Hope this helps some. Watch "Fog lights on 2011 LS" on YouTube
01-29-2014, 04:03 PM | #3 |
Do you have the OEM harness, the PnP harness from Ofer or a aftermarket harness? Here is a couple pics for a aftermarket harness. Let me know
01-29-2014, 04:08 PM | #4 |
That's a great picture! It's the harness from Ofer
01-29-2014, 05:05 PM | #5 |
Some more pics.
01-29-2014, 06:17 PM | #6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Step 1: Remove the 3 torx screws securing the wheel well liners to the front bumper on each side, this will allow access to backside of the bumper
Step 2: Remove the bumper plugs, by releasing the tabs and pulling out the backside of the bumper Step 3: Install the foglamp thru the front of the bumper and ensure that the 3 mounts snap in tight Step 4: Install the foglamp bezel from the front side of the bumper. Step 5: Locate the wire harness on the passenger side of the bumper where the body harness plugs into the bumper harness. Step 6: Disconnect this connector and put our connector inline, and reattach. Step 7: Plug the foglamp wires into the lamps Step 8: Connect the ringed terminal wire to the stud in the underhood fuseblock. See photo for stud location Step 9: Switch installation: Run the single wire from the relay, into the car and find a suitable location to mount the switch. Connect the wire to the center terminal of the switch. Run the other 2 wires from the switch over to drivers side fuse block. Remove fuse #F17 (power outlet 1) from the fuse block and install it into the empty cavity on the add-a-fuse, then connect the add-a-fuse into F17. Install the ringed terminal wire to a good ground. Step 10: Secure the relay up and out of the way with ziptie's Step 11: Verify function: Should be able to turn lights on and off with switch when vehicle is running. P.S. there on the site in the Installation Instructions tab. |
03-29-2014, 09:51 AM | #7 |
Drives: 1LT; IBM; 6 Spd Manual Join Date: May 2009
My son just bought a 2013 and the lights are installedbut not activated,no harness. Where can we get the harness alone and what do they cost? Is there a stock connector that the harness taps into the system? There is no seperate fog light control switch on his headlight switch, like my 2010, so assume they tap into a stock connector and are on whenever the headlights are on?
Thanks
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I] |
