11-12-2014, 09:50 AM | #1 |
Drives: 2011 CAMARO SIM 2SS/RS Join Date: Nov 2012
offset question ???
I'm looking at buying a set of 20x10s with a 40mm offset all around. Anyone running this setup? I'm running split drop springs and the stock brembos? Am I looking at clearance issues? Will these stick out?? Any help is appreciated before I pull the trigger on these.
11-12-2014, 11:39 PM | #2 |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
I don't believe they will fit on the front. Section width of the tire is a factor.
What I know: A 9.5 wheel, 40mm offset, and an 11.5" section width tire touches the factory strut. Stephen12ZL1 is running 20X10 30mm offset wheels with 285-35-20 tires F and R. I have read on this forum that 30mm is the largest offset you can run using 295-35-20 tires.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
11-13-2014, 06:17 AM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
they will NOT fit on the front
11-13-2014, 09:35 AM | #4 |
Didn't think so. Sucks cause I found a steal for a set of drop stars on CL out here.
12-06-2014, 10:45 AM | #5 |
