07-09-2012, 11:50 AM | #1 |
Drives: 2011 Camaro Join Date: Apr 2012
Steering wheel
How much do y'all think a Zl1 steering wheel would be? My rubber one ain't cuttin it haha
07-09-2012, 12:42 PM | #2 |
Drives: Blue Join Date: May 2012
Well I was told at the dealership that my 2011 one cost 1200$ soooo there is a rough estimate for you :P 1200$ plus some!
07-09-2012, 02:07 PM | #3 |
El Chupacabra
Drives: 2011 2SS/RS A6 Black/Black Join Date: Jun 2011
That dealer is a rip off. I believe I've seen the 2010-11 wheel for about $350 or so, and the 2012-13 should be about the same. Of course, the dealer may be quoting a wheel WITH airbag. Those airbags aren't cheap.
If you're just wanting to swap out a stock 2012 wheel for a ZL1, you can use your current airbag. Never mind. Just noticed you have a 2011. Just get a 2010-11 leather wheel, unless you want to blow a lot of cash.
El Chupacabra
Last edited by REDXIIIDave; 07-09-2012 at 02:09 PM. Reason: Didn't see OPs model year |
07-09-2012, 07:48 PM | #4 |
I actually saw on this site a leather steering wheel with red stitching for 110 . . That's not bad at all. I just like the velvet type material on the zl1 wheel.
07-09-2012, 08:04 PM | #5 |
We can swap it from mild to wild...few examples...options = limitless
07-09-2012, 08:08 PM | #6 |
Drives: White M6 1LT RS Join Date: Mar 2010
You better off taking your steering wheel and getting Alcantera stitched on by a upholstery shop. Much cheaper!!
This guy does BMW wheels with Alcantera for around 175 bucks and they look very professional. http://cobywheel.com/ I spoke to him before and he thinks he can do our wheels too. Problem is you need send him your wheel and this is my only car.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
07-09-2012, 08:48 PM | #7 | |
07-09-2012, 08:54 PM | #8 | |
Drives: Drives a 2012 IOM 2SS/RS 6M Join Date: Nov 2008
maureen@Rogerschevrolet.com
CAMARO 2SS/RS 6M
07-11-2012, 12:29 AM | #9 | |
