03-17-2017, 07:21 AM | #1 |
Drives: 2011 Camaro SS Summit White Join Date: Sep 2015
L99 to ls3 conversion: Cam question
If I do the L99 to LS3 conversion, do I need to chose a l99 specific cam still? Or can I now use ls3 cams?
03-17-2017, 07:32 AM | #2 |
Yes if you do the conversion you will use a LS3 cam. They have came along way with VVT cams though. Some really great options to utilize your L99.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
03-17-2017, 07:46 AM | #3 |
I've heard you're better off going ls3 conversion and you'll make more power that way...
03-17-2017, 07:50 AM | #4 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Mid to upper rpm, yes, but lower rpm's might lose some power according the cam choice.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
03-17-2017, 02:56 PM | #5 |
Drives: 11' RJT 2SS/RS L99 Join Date: Jun 2014
If you have a shop near you willing to tune the vvt cam i would not do the full LS3 conversion. Take a look at the forum's fast list, majority of the fastest automatics have a vvt cam. Gwatney Performance Innovation seem to have the vvt figured out on these cars.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall 1LE 3.91s Stainless Power Headers w/cats Fluidampr 25% UDP Cold Air Inductions Intake Bo White Ported Throttle Body ADM Trans Cooler Some BMR Goodies |
03-17-2017, 03:04 PM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
Keep vvt...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-18-2017, 05:40 PM | #7 |
Drives: SW 2SS/RS L99 Join Date: Mar 2012
GPI VVT Cam
03-18-2017, 07:26 PM | #8 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
IIRC, it was an LLSR with lots of lift that took one of their Camaros into the 9s.
03-18-2017, 08:35 PM | #9 |
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-19-2017, 03:36 AM | #10 | |
Moonshiner
Drives: Holden SS-V L77 flex fuel Join Date: May 2012
That's an old wives tale. Think about it, if that were true then most modern advanced performance engines would not run VVT, but they do. So not more power without it, no. As much peak power is possible, definitely. Unlikely without VVT it would have as much power across the RPM range. But it is in tuning the torque model that gives VVT its advantage.
Compression is King.
Naturally as-pirated, all-motor, all alcohol. |
