01-07-2020, 09:30 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Aug 2016
Engine swap question
If I were to put an ls1 into my 2010 camaro ss, what would be needed aside from harness adapters to make the harness work? I assume all the belt driven accessories and transmission all mate together but maybe I’m wrong about that too
01-07-2020, 10:29 PM | #2 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
why??? what's wrong with the ls3???
01-07-2020, 11:29 PM | #3 |
Curious about a truck motor build. It’s odd but budget friendly, seems easy to put an ls3 into an ls1 car but curious about ls1 to ls3
01-07-2020, 11:31 PM | #4 |
Ponies are for girls
ECU
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
01-07-2020, 11:33 PM | #5 |
The whole eco? What if it was a more recent truck motor like a 6.0 or 6.2
01-08-2020, 04:51 AM | #6 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
You're not making any sense bud. You already have a 6.2L....... Why would you downgrade to an LS1? And a truck engine is heavier unless it's the Caddy L92 or other alum block 6.2L. Not sure what the point is of doing such a thing tbh......
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
01-08-2020, 05:13 AM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
More to come. |
01-08-2020, 07:09 AM | #8 |
Started#gottalovethatblue
There's enough different between the two. ECU is definitely something that will be different, but the wiring harness may be pretty different between the two since the LS1 was replaced for the LS2 in 2005. For example, the LS1 has a cable throttle body vs. our computer controlled one. Additionally as others have said, why go from 6.2L to 5.7L? After all, there's no replacement for displacement.
01-08-2020, 07:12 AM | #9 |
I wouldn’t get too focused on the ls1 but in general a truck block, would I be better off switching to a newer truck motor? Everyone is looking at me funny like no one has ever put an iron block truck motor into a 5th gen before. Only said older cause I figured it’d be cheaper
01-08-2020, 07:26 AM | #10 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
There are many that have done iron block 6.0 yes. The LS1 isn't and power limit for that block is significantly less than an ls3. Are you talking an L96 6.0? Everyone is looking at you funning because an LS3 is superior to an ls1 in every way expect cost
01-08-2020, 09:18 AM | #11 | |
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
01-08-2020, 09:23 AM | #12 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Maybe he's talking about the LT1? (typo perhaps)
01-08-2020, 11:35 AM | #13 |
Wife named it "Ghost"
Drives: 2012 Camaro Summit White 2SS/RS M6 Join Date: Jan 2017
Also, there is the different reluctor wheel between older LS engines vs the LS3 24X vs 58X that would have to be matched to the ECU. There was a lingenfelter box for conversions, but probably going to an older system would wind up not being cost effective either since so much wiring and differences in connections. Unless it's strictly a drag car that is going to be gutted, probably too much of a headache. Just an opinion....
2012 2SS/RS Camaro M6 Summit White
01-08-2020, 11:53 AM | #14 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
