07-30-2018, 01:57 PM | #1 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
LSA conversion ?
Does anyone else offer an 8 rib setup for those that have an SS (2015 1LE) and have had the LSA conversion done? My belt keeps jumping a rib under load on the stock SS 6 rib. I am aware of the ADM 8 rib, but Andy say's he no longer sells it. Any help is appreciated.
07-30-2018, 02:06 PM | #2 |
@LS.ACE
Drives: 2014 Chevy Camaro 2SS/1LE Join Date: Jan 2017
you would have to get the whole zl1/cts-v accessory drive
Some weird snail with a belt on it | Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |
08-03-2018, 10:10 PM | #3 |
Drives: 2015 Camaro 1LE Join Date: Jun 2016
How are you routing your belt I’ve never had this issue PM me maybe I can help you
08-04-2018, 10:33 PM | #4 |
@LS.ACE
yea hit up 1LEric he definitely knows what he's doing with that LSA setup. And he is always on full send.
08-04-2018, 11:32 PM | #5 |
'It's an experiment'
6 rib setup. I never had an issue... do you have the right belt length? ADMs 3 belt setup: https://www.camaro5.com/forums/showp...postcount=1557 There is a tweak done so you can keep the original ac otherwise, need the zl1 accessories... -Don
747 RWHP 794 RWTQ
08-05-2018, 11:35 AM | #6 |
Guaranteed this is just a matter of centering the belt on the tensioner and upper pulley
08-05-2018, 12:04 PM | #7 |
Yep, was hoping the pic would help.
Here is the install guide just in case: https://www.camaro5.com/forums/showthread.php?t=514480 Post a pic of your belt routing and I'm sure someone can verify it... -Don
747 RWHP 794 RWTQ
08-06-2018, 02:53 PM | #8 |
Best pic I have right now
08-06-2018, 06:21 PM | #9 |
Here is a side side view, note how the belt is arranged on the pulleys:
Groove on each side of the belt (since these are 8 ribbed pulleys) -Don
747 RWHP 794 RWTQ
08-06-2018, 10:20 PM | #10 |
Drives: Victory Red Join Date: Jul 2017
When I did my swap, I got the entire front accessory parts from a zl1, zl1 alternator, reused my stock power steering pumpwith a zl1 power steering pump bracket, cut a piece off my driver side valve cover power steering pump would fit correctly, and didn't run ac.
08-08-2018, 01:21 PM | #11 |
Drives: 2014 1SS/RS Join Date: Jul 2014
I had this problem too. Running a tighter belt but now I’m getting a squeaking noise (sounds like the idler pulleys). Doesn’t sound like a screeching belt. Anyone have this issue with the adm ldle pulleys?
08-08-2018, 01:54 PM | #12 |
Theses should help if you need to replace the pulleys:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 -Don
747 RWHP 794 RWTQ
08-08-2018, 03:00 PM | #13 |
Thanks for the info. I haven’t had much time to really find the issue. Will try this weekend and update.
08-08-2018, 10:06 PM | #14 |
I had that too Took all my pulleys apart and regreased them with high temp red grease
