01-17-2014, 05:50 PM | #1 |
Drives: 2SS/RS,Wrangler,CTSVcoupe,viper,etc Join Date: Apr 2012
Pfadt headers/ borla atak
Just installed both with pfadt hi flows
Welded cats to borla exhaust After a few heat cycles The passenger side header is 'just' touching the crossmember Slow speed turns and low idle are an annoying rattle, Will the self locking jrp header bolts help realign? Any one else have header clearance issues? |
01-17-2014, 06:35 PM | #2 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
I didn't have any issues with the Tri-Ys connecting to the factory pipes, but had to readjust the SW retro chamber exhaust after a few hundred miles. Now it's good to go, even on dirt washboard sections of county roads.
01-17-2014, 07:06 PM | #3 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
Welding is a bad idea..makes it hard to make adjustments. I would take it to an exhaust shop and get them to fix whatever the issue is. Locking bolts won't help.
01-17-2014, 07:12 PM | #4 |
Drives: 08 G6 GXP Join Date: Jul 2012
Can we see some pics where its hitting and of the install. This should not happen with what you spent on them
01-17-2014, 08:16 PM | #5 |
Drives: 2011 2SS/RS Camaro Join Date: Feb 2011
Exactly. Don't they bolt right up? Should've never welded them. This is your shops problem, not Pfadt or Borla.
2018 ZL1 A10
2011 2SS M6. CAI, ATAK, OBX LTs (JRE tune) Autoclub Dragway Best ET: 12.785 Dec 3, 2011. Autoclub Dragway Best MPH: 112.01 Jan 7, 2012 |
01-18-2014, 04:46 PM | #6 |
What other way would I attach the cats to borla pipes?
Another question, I heard a lot about heads becoming loose over time? How do ji combat this? |
01-18-2014, 06:09 PM | #7 | |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Please don't take this the wrong way, but if you can't do the work yourself, or if it's beyond your comfort level, don't do it. The pipes should not have been welded and now you may have to spend even more money getting it fixed. |
01-18-2014, 06:12 PM | #8 |
Also, there is a screw on the passenger side that comes out of the frame and can contact the header. This happened to mine and it caused a rattle at low speeds.
01-18-2014, 07:55 PM | #9 | |
You reuse the factory barrel clamps. That is how every header that uses mid pipes works.
01-19-2014, 12:11 PM | #10 | |
Turns out, the reason why I have some clearance issues Is due to a cracked motor mount Guess I ran it too hard at the track lol Fixed under warranty now |
