04-13-2017, 09:09 AM | #1 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
Recommend strut / shock replacement
I have an '11 SS/RS w/ ~77K miles on it with the OE struts / shocks. It's my daily driver, it's not tracked or anything. No suspension mods. What are good replacements for a DD? AC Delco, Koni, KYB, Bilstein,.... I guess I'm looking for as good to a little better than stock. I was kinda leaning towards the Koni orange.
04-13-2017, 09:30 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
1LE setup.
Orange Krush II
04-14-2017, 07:43 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Factory FE4's are even better than our originals.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-14-2017, 10:42 AM | #4 |
04-14-2017, 01:22 PM | #5 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
the 1LE uses FE6 suspension........
part numbers here: http://www.camaro5.com/forums/showthread.php?t=244570 the shocks will be quite a bit stiffer than the ones you now have (ss & 1LE springs are the same). if you are happy with the current ride, stick with stock. once you change one thing, you will end up changing a lot of things..........the afliction is called mod fever
04-14-2017, 01:49 PM | #6 | |
04-18-2017, 10:17 AM | #7 |
Drives: Race Car Join Date: Sep 2009
I stock both Koni Oranges & Sport Yellows!
And there is a Factory Rebate program going on right now. |
05-29-2017, 04:05 PM | #8 |
So, I went with the Koni orange. I didn't get the lowering springs. Although it would look better, I didn't want to increase ride stiffness. The front bolts that attach the struts felt like Hulk tightened them at the factory. Even after soaking them w/ WD40 it felt like I was going to snap by breaker bar in half. Next stop, the alignment shop.
05-30-2017, 11:36 PM | #9 |
USA-1
Why did you go with Koni Orange over just going to the newer 2012 style?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
06-01-2017, 03:59 PM | #10 |
Drives: 2013 Camaro SS Join Date: Apr 2017
I just went with the 1LE shocks and couldn't be happier. They are everything I was hoping they would be.
06-02-2017, 07:45 AM | #11 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Just an FYI not sure about the Koni orange but with the koni yellows spring seat shape and height difference factory 245 45 R20 height tires will not fit on the front of my 1LE anymore with the konis. (Sorry for the garbage sideways picture)
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
06-02-2017, 07:46 PM | #12 |
Yeah, I didn't want to go for a lower ride height, so that's why I stuck w/ the orange. The problem I'm having now is the infamous knocking noise from the front end. I'm gonna go back in & tighten everything back up. I may even try the toilet mod if that doesn't work.
09-29-2017, 07:30 PM | #13 |
I thought I'd update this thread. After installing the Koni oranges, I was getting some popping noises. I went to this thread:
http://www.camaro5.com/forums/showth...=49036&page=18 I checked & re-tightened all the nuts & still had the popping noise. I then installed an advanced rubber isolation bushing system or ARIB (it' really called the toilet mod) There's a rubber toilet flange that just fits perfectly on top of the strut tower to eliminate the popping noise. pics here (not mine): http://www.camaro5.com/forums/showpo...3&postcount=31 Worked like a charm. Now that everything is settled in, I find the ride a little softer than OEM. Most of you would probably prefer a stiffer strut. I usually do too. However, with my bad back, the softer strut is much more comfortable. The adjustable Koni yellows would be a better choice for anyone looking for a performance upgrade. The orange are good if you want performance w/ comfort. |
Thread Tools | |
