07-11-2012, 10:15 AM | #1 |
Drives: White SSRS Convertible Edelbrock SC Join Date: Sep 2009
When should cooling fan kick on?
I have the eforce installed on my SS.
I noticed that when the car was idling the temp. went up to 214 degrees F and the fan was not running. Seamed odd to me. When driving and not being pushed the temp. is normal between 180 and 190 F. Shouldn't the rad cooling fan be running at 214 degrees F ? |
07-11-2012, 10:18 AM | #2 |
Drives: 2012 1SS Join Date: May 2011
mine don't kick on till around 221.... I thought that was alittle hot but they say it's normal
07-11-2012, 10:23 AM | #3 |
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
Around 225+-
07-11-2012, 10:23 AM | #4 |
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9 Join Date: Jul 2012
I agree with calgrown562, from testing many cooling systems in the shop the cooling fan will usually come on about 220-225 and shut off around 195, unless the a/c is turned on then it should come on everytime the compressor engages.
07-11-2012, 10:32 AM | #5 |
Let's go Rangers!
Yep over 220, closer to 225.
07-11-2012, 10:34 AM | #6 |
Drives: a Panty Dropper Join Date: Feb 2012
IDK mine turns on right at 195 or 200
07-11-2012, 11:08 AM | #7 |
Drives: IOM 2SS/RS Join Date: Jul 2009
My tuner set the fans to come on earlier than stock. Somewhere around 198 the fans are on full and my temps max out about 203 before falling to the mid 190's. This is while idling only. Your tuner should have set your fans to come on earlier, especially with an eforce installed. You must have a 160 degree thermostat installed for the temps to be between 180 and 190 while cruising.
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
07-11-2012, 12:05 PM | #8 |
Drives: 2010 CAMARO 850 RWHP/733 RWTQ Join Date: Sep 2010
My fans are set to come on at 192.. Car runs about 195 with a/c in stop and go traffic. 185 without a/c.. But this is true before tune mine came on at 221
*Night Fury
*Vortec YSI *Alky Meth *RPM TH400 with Brake *Precision 3600 Converter *850 RWHP/733 RWTQ |
07-11-2012, 12:54 PM | #9 |
H1 OFCR
Drives: 2013 ZL1 Blue Ray Metallic Join Date: Jun 2011
I thought they should be around 180??? Hmmm
Corsa
Rotofab BBK ZL1 Hood/Fascia AAC Afterburners/Sidemarkers Havoc Black Chrome 5% Tint/20% Smoked Taillights |
07-11-2012, 01:04 PM | #10 |
Drives: Camaro 2SS/RS Ice Silver Join Date: Oct 2009
Fans will kick in if ECT reaches 212° if a/c is on it kicks earlier.
Normal engine temperature ranges from 194° to 212°. Sent from my GT-N7000 using Tapatalk 2 |
07-11-2012, 01:27 PM | #11 |
Thanks guys.
Stuff like this is the real value of this forum. So we can compare notes. I will see if my tuner will set the temp. lower. Wayne |
