04-02-2016, 10:26 PM | #1 |
Drives: 2013 camaro zl1 Join Date: Feb 2016
Diy cam install in my ZL1
Im looking for a bit of encouragement. I am planning on installing a cam, pushrods and springs in my ZL1. I have done many cam installs on my own, but never in an LSA. I am doing the install without removing the heads or intake. Any advise will be greatly appreciated
04-02-2016, 10:43 PM | #2 |
Sarcasm loading --------
Its not a bad job. You dont have to remove the heads or intake, follow the cam install DIY for an LS3, it will be the same.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
04-03-2016, 10:42 AM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
04-04-2016, 11:01 AM | #4 |
excellent, this will help a lot. appreciatted
04-20-2016, 09:33 AM | #5 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
I spent a lot of time trying to lower the oil pan to make the oil pick up bolt easier but in the end the pan only dropped about a half inch. That may have been necessary though because that bolt was hard. To put the bolt in I had a friend "pry" the oil pan down against the pick up tube. He barely applied any pressure but it helped.
I don't know the year or model differences but my battery cable is not routed the same as on the 2010 in this thread http://www.camaro5.com/forums/showthread.php?t=125123 on mine the battery cable is in a metal tray like thing under the oil pan which is what made it much harder to lower the pan. |
05-25-2016, 08:41 PM | #6 |
I just finished installing my texas speed stage 3 cam, springs, push rods and large intercooler. It was a pretty big job for me, but it went pretty smooth. That link helped a bunch. Dyno next week. Idle definately needs to come up a couple hundred rpm,s but sounds freakin good
05-30-2016, 07:34 PM | #7 | |
05-31-2016, 09:12 AM | #8 | |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
For the most part, this is a straightforward - but not necessarily simple - project. All but a handful of the fasteners are easy to reach, but there are a lot of parts that need to be removed. Make sure to have the correct tools on hand, and keep your parts and fasteners well-organized. It'll be a 20ish hour project the first time through, so make sure you have enough time set aside to avoid rushing through the project.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
06-01-2016, 08:51 PM | #9 |
Dyno run today. Not so good. Runs out of fuel at 4500 rpms. I get to install a new fuel pump this weekend. I knew this was a possibility. Oh well, all part of it.
06-02-2016, 03:46 PM | #10 |
I am going to install the jms fuel pump voltage booster, should take care of my fuel pressure issues. Then its back to the dyno
06-02-2016, 03:46 PM | #11 |
Drives: 2013 ZL1 #505 Join Date: Nov 2012
06-02-2016, 03:48 PM | #12 |
07-01-2016, 04:26 PM | #13 |
My dyno sessions are done, after the jms voltage booster the fuel pressure is steady 65psi all the way to 6500rpms. This car made 635hp and 640lb ft at the wheels. Outside temp was near 100 degrees and humidity also 100 percent. Im very happy with the numbers. This car is a beast
07-01-2016, 04:32 PM | #14 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
What other mods? -Bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
Thread Tools | |
