Old 12-09-2018, 09:09 AM   #1
Chester
Drives: 2015 Camaro SS
2010 Camaro SS stabilizer bar
Was changing front and back struts yesterday. Can anyone in lighten me why there is only 1 stabilizer link on the rear sway bar, passenger side?
Chester is offline   Reply With Quote
Old 12-09-2018, 08:29 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
You're going to want to get that fixed ASAP.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-09-2018, 08:49 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
The rear sway bar has a link on each side (just like the front sway bar). You're missing one. I'm surprised you didn't notice anything wrong in the handling before.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 12-09-2018, 10:44 PM   #4
CamaroFred
CamaroFred's Avatar
Apparently he did, what with changing the struts...
2011 1SS/RS LS3 CGM
Old 12-09-2018, 10:52 PM   #5
hammdo
'It's an experiment'
hammdo's Avatar
May want to make sure the support on the lower control arm did break off too on the missing side...
-Don
747 RWHP 794 RWTQ
Old 12-09-2018, 11:30 PM   #6
CamaroFred
CamaroFred's Avatar
-Don
Common issue when installing a stiffer rear sway.
There is a fix for that:
ELK009 End Link Mounting Brace, Rear Lower Control Arm
You will need to have a good welder, or for less money, a new control arm, if it did break off.
2011 1SS/RS LS3 CGM
Old 12-10-2018, 08:00 AM   #7
Chester
-Don
Did some rechecking yesterday, the stabilizer link mount on the lower control arm was broke off pretty even, thought there should be one Couldn't see it until right up close. I bought the Camaro this summer, going over it (winter project). New control arm and links ordered. Thanks to all
