Old 09-11-2019, 06:12 AM   #1
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Powder Coat or Paint?
Having no experience with painting or powder coating wheels I come to you for advise.
"Toying" with the idea of EITHER painting or powder coating a set of aluminum wheels to match my Ashen Gray Camaro.
1. Which do you think would be so most durable and lasting process?
2. Any idea of the approximate cost for a set of wheels?
Please let me know what you know or especially what you have experienced, good or bad I value your input.
Thanks
Larry
Deputy347k9 is offline   Reply With Quote
Old 09-11-2019, 06:49 AM   #2
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
[QUOTE=Deputy347k9;10617718]Having no experience with painting or powder coating wheels I come to you for advise.
Larry
My experience with powder coating and or painting wheels was when I priced out having a set of wheels done.Depending on if you have any scratches,chips & scrapes needed to be repaired,tires on or off the wheels,the quoted cost was $125 a wheel for painting.Powder coating color change was another story,tires have to be off the wheels.because of the 450 degree heat,by the time the quote was finished it was $900+ for the set.I ended up buying a new after market square set of 10x20 gold "Hurst"wheels,which were stolen last winter,new tires and locking lugs,That's another story.Call,text or email any of the wheel repair businesses,they'll enlighten you.Stay local,it could cost up to $50 a wheel to ship.... Good Luck!
steakmaker is offline   Reply With Quote
Old 09-11-2019, 06:53 AM   #3
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Thanks
Larry
I would powder coat them. They will last longer and the finish will be better for road wear.
ZEN357 is offline   Reply With Quote
Old 09-11-2019, 07:05 AM   #4
500hpbluez28
YUDLOSE
500hpbluez28's Avatar
Drives: Supercharged 2010 ABM 1SS
I have done both. Having them painted was a quick turnaround, didn't have to unmounts tires and got the look I was going for but over time it did get nicks from daily use. Powder coating is more durable and will most likely be the more expensive option. If you just want to get a new look for awhile and don't daily it you may can get by painting them. If you plan to keep the wheels on it and want it to last I would suggest powder over paint.
Trey Jenkins
2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009
1996 Blue Z/28 Camaro 396 stroker in the process
1994 Red Z/28 Camaro
500hpbluez28 is offline   Reply With Quote
Old 09-11-2019, 07:51 AM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
Another alternative, plasti-dip. I had a set done a few years ago for $300. Multiple times on and off the car and no issues with peeling. And when you get tired of the color, dip them again.
Vegas Bound is offline   Reply With Quote
Old 09-11-2019, 07:49 PM   #6
Deputy347k9
[QUOTE=steakmaker;10617727]
Larry
These are new wheels, no tires mounted, no damage and yes I plan on staying local. Mine is also a square setup of 10X20. I am really thinking of going with a match to the vehicle color of Ashen Gray. Thank you very much for all the very informative advise.
Old 09-11-2019, 07:50 PM   #7
Deputy347k9
I too thought powder coating would last longer and hold up better than the paint but "extremely" worried about damaging the finish when mounting the tires?
Any tricks of the trade when mounting?
Old 09-11-2019, 07:51 PM   #8
Juiced1
Drives: 2012 2SS CAMARO 45th
We have a shop next to us that repairs wheels and does powder coating. They say the powder coating holds up a lot better.
Juiced1 is offline   Reply With Quote
Old 09-11-2019, 08:00 PM   #9
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Powdercoat is more durable. Your car is painted, no reason you can't paint the wheels. They will look better painted. If they aren't going to see salt or many trips down gravel roads I would paint them.
I had mine painted last year and have no regrets. No chips so far and they shine!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-12-2019, 04:31 AM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Powder coating a good option I had my stickers done a few years ago an no issues short of my wife curbing them because she couldn't see.
Powder coat shouldn't cost more than 75-100 bucks a wheel.
Mine was 250 since I knew the guy.
Orange Krush II
Old 09-17-2019, 10:20 AM   #11
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Powder coating is definitely more durable, but the wrong tech can surely screw it up. If you can get a shop that sells aftermarket wheels, they usually know how to avoid nicks. They might not know much else, but if they sell wheel and tire packages they are mounting tires on expensive wheels all day every day. Doing a set of ZL1 wheels was $340 at the shop I went to. Most of the powder coating shops around here focus on bikes and they wanted over $500.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 09-17-2019, 10:26 AM   #12
Deputy347k9
I just got off the telephone with RGX, a powder coating company out of Wilmington, NC: One to two weeks turnaround, because the wheels are new with no tires mounted they will only charge me $175.00 "PER" wheel.... $700.00 for 4, I didn't expect that.
Old 09-20-2019, 07:51 AM   #13
CamaroCracka
Find another company. Mine were $85 per.
Old 09-21-2019, 07:46 AM   #14
chrish70
Drives: 2015 ls3 camaro ss
powder coat it stronger, there is a place here in cleveland that does wheel called advanced paint tech
chrish70 is offline   Reply With Quote
