Old 09-21-2019, 10:10 PM   #1
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
Drag Radial Storage
How are you storing your drag radials for off season? Should you air them up to max psi? Lean them up against garage wall or lay them on floor stacked on top of each other? Put on blocks to keep off floor?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 09-21-2019, 10:40 PM   #2
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Best way is to keep them in trash bags in the house, avoid concrete, uv rays and extreme temps, normal psi.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 09-22-2019, 09:13 AM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Mine are at 20psi. Inside the house. Lay flat on top of each other.
Don't let them go below freezing temps.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 09-22-2019, 09:54 AM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Away from sun, dries them out.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-22-2019, 10:25 AM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
Use them up in one season.
Vegas Bound is offline   Reply With Quote
