JUICEDMOTORSPORTS
Old 09-27-2018, 01:41 PM   #1
Torrin60FTyou
Torrin60FTyou's Avatar
Drives: 2015 camaro 1ss
Manual nitrous options
What’s the best nitrous set up options for a manual car besides having it on a WOT switch? what do you use? a button or what??
Torrin60FTyou is offline   Reply With Quote
Old 09-27-2018, 02:03 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Wot switch unless you want to blow your motor up
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-27-2018, 04:37 PM   #3
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Window switch and LNC2000.
N.O. Plate(dedicated fuel tank, progressive, fuel hose upgrade, remote opener, heater, console switches), LNC2000, CTAP, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer WB, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 09-28-2018, 09:57 PM   #4
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Innovate PSN-1 gauge has a built in window switch, lean cut off, and low bottle pressure shutoff. I like mine a lot
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
