Phastek
Old 12-05-2019, 09:30 PM   #1
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
Just bought a 2012 SS that has a weird idle surge. Please help...
I just bought a 2012 SS with an L99 with only 19K miles on the odometer. Apparently the car was sitting for a long time. First thing I did was change the oil with some good ole Mobil 1. We also checked the rear diff fluid as well and it was pretty bad. So, we changed that fluid as well. However, the car seems to have a slight idle problem. It sometimes has a slight surging condition that goes up and down. It doesn't do it always, just sometimes. So I'm wondering what can or could I do or replace so the engine idles normally?
bumblebeecamaro is offline   Reply With Quote
Old 12-06-2019, 07:54 AM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
There are too many factors -- you'd really need to record your idle with HP Tuners (etc.) and post the log.
It could be anything related to fuel, air, spark, bad tune...
As for the diff fluid, even when it's fresh from GM, it stinks to high heaven. I doubt it needed to be changed, but it's better that you changed it just to be sure.
Jack Bilger
granatl is offline   Reply With Quote
Old 12-06-2019, 08:57 AM   #3
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Is the car stock or modded? Usually when we get an erratic idle we usually look for air leaks. Check the intake and vacuum lines to make sure you don't have any open or loose connections.
We carry & install all the hottest brands for your 5th/6gen Camaro. Get awesome deals & install rates! Call or Pm us for your CAMARO5/CAMARO6 discount. 224-63-JUICE or INFO@JUICEDMOTORSPORTS.COM ST CHARLES IL
Juiced1 is offline   Reply With Quote
Old 12-06-2019, 09:49 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
clean the maf and tb....
Good luck!
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 138K! - All work by me...
Old 12-06-2019, 04:30 PM   #5
bumblebeecamaro
Car Lover By Nature
The car is bone stock but it sat in storage for a long time. It's not an erratic idle more like a rise in rpm here and there but nothing too bad. I'm just use to smooth running engines. My 2010 SS idled really smooth.
Good luck!
PEACE
Thanks I'll try that. What should I use to clean those two things? Would brake clean do the job w/o hurting anything?
Old 12-06-2019, 04:58 PM   #6
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
They make an actual MAF cleaner. I don’t think brake clean is a good option. Could be wrong , hopefully someone with experience will chime in.
HOJO is offline   Reply With Quote
Old 12-06-2019, 08:47 PM   #7
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
Autozone or NAPA sell throttle body cleaner and MAF cleaner.
My car sat for a while before I bought it. I wasnt sure what kind of gas was in it, so I ran a 3-4 of tank fuels of 93 octane with injector cleaner and seafoam in it, to clean out the fuel delivery system.
It could be some light misfires from the injector being a little clogged.
If you didnt say the car sat for a while, Id look for a dry rotted hose creating an air leak.
2013 ZL1 Camaro A6. ARH Headers, K&N intake, street Tuned by Tampa Tuning
ABM Camaro is offline   Reply With Quote
Old 12-06-2019, 10:12 PM   #8
bumblebeecamaro
Car Lover By Nature
So you put the fuel injector cleaner in the tank?
Old 01-06-2020, 08:31 AM   #9
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Might be old gas.
Run it out with some sea foam, then change fuel filter and put fresh gas in.
2010 CGM Camaro 2SS RS A6 760rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Converter
Kooks Jet Hot Ceramic Coated Headers
Kooks full true 3in exhaust
Trick Flow GenX 255's with Polished PAC .660's and Ti-retainers
Texas Speed VVT 3.2 cam kit w/DoD Delete
Texas Speed 1.72:1 Roller Rocker Arm Set
AEM X-Series OBDII Widebands
Fuel Injector Clinic ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Fuel Kit + E85
DSX Auxiliary Fuel System
JRE 6L80E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
