Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 08-23-2015, 03:20 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
2 piece wicker bill for Z/28, 1LE and ZL1 type spoiler
Many members have asked for this wicker bill and we have them made for the Z/28 type spoiler and the ZL1 spoiler, we also have the 2 piece wicker bill for the 1LE all years. Its made of tough Lexan and comes with all hardware. the center section is smoke clear with black sub section. the proto type here has extra holes the production will not and will be adjustable. Interchangeable with OEM wicker bill. Uses same hole patern and bolts.
Skylane765 is offline   Reply With Quote
Old 08-23-2015, 03:22 PM   #2
v6maro
v6maro's Avatar
Drives: 2014 camaro
Originally Posted by Skylane765 View Post
Many members have asked for this wicker bill and we have them made for the Z/28 type spoiler and soon the ZL1 spoiler. its made of tough Lexan and comes with all hardware. the center section is smoke clear with black sub section. the proto type here has extra holes the production will not and will be adjustable.
How much is it ???
Sent from my SAMSUNG-SM-G925A using Tapatalk
v6maro is offline   Reply With Quote
Old 08-23-2015, 03:25 PM   #3
Skylane765
Skylane765's Avatar
You can go to our site www.zl1addons.com
Old 08-23-2015, 03:34 PM   #4
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Can a factory wicker bill and this one be interchanged? Are the mount holes the same?
Zslash28 is offline   Reply With Quote
Old 08-23-2015, 03:49 PM   #5
Skylane765
Skylane765's Avatar
YES. They use same hole pattern
Old 08-23-2015, 04:02 PM   #6
v6maro
v6maro's Avatar
Drives: 2014 camaro
So is the whole wicker adjustable? It just the middle peice ? And do ya'll have the production one's in stock ?
Old 08-23-2015, 04:25 PM   #7
Skylane765
Skylane765's Avatar
Only center section is adjustable per the members. I have the OEM but we do not sell them its for my Z/28. GM has the metal OEM type. But we make a Lexan in smoke clear or black copy of the OEM wicker bill its 1/3 the cost of the OEM.
I do not understand why the OEM bill is adjustable? Because in the down position it is even with top of the spoiler, so why not just remove it?
Old 08-23-2015, 05:14 PM   #8
v6maro
v6maro's Avatar
Drives: 2014 camaro
Okay. I'm about to order from you guys. Just to clear it up. I get everytging in the picture right ? Besides the car and spoiler of course. Or is it just the clear attachment. I'm just confused haha. Because the price is beyond perfect if it comes with everything !
Old 08-23-2015, 09:09 PM   #9
X25
X25's Avatar
Drives: '16 C7 Z51
I ordered one as well. I won't need the rivets, etc., since I already have the OEM wicker bill. If anyone needs the installtion hardware, let me know.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 08-23-2015, 10:43 PM   #10
pimp2303
Drives: 2014 Camaro Z/28
Does this come with the template.
pimp2303 is offline   Reply With Quote
Old 08-23-2015, 11:17 PM   #11
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
Lots of people are running the cheap ebay copies of the Z28 spoiler- I'd imagine this would fit that just fine. I'll give it a shot and try it.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 08-24-2015, 02:02 PM   #12
Skylane765
Skylane765's Avatar
Yes, it should fit just fine if it has a hollow spoiler. If a solid spoiler they will also work by just threading into the material.
Old 08-24-2015, 02:07 PM   #13
Skylane765
Skylane765's Avatar
We found a much better way of marking the holes with the wicker bill itself, I did my first OEM and the template does not work as easy as using the wicker bill to mark the holes. Instructions come with it. When I used the OEM template it is not very easy to keep lined up and strait because of the thin paper. You just mark a single hole in the center and screw the center of the wicker on and then tape the two sides and mark it. I have done it both ways. we are going to change to 1/4 20 from m8 bolts to help keep the install easier and less cost for the tool.
Old 08-24-2015, 02:08 PM   #14
Skylane765
Skylane765's Avatar
If you do not need the hardware shoot me a email right away and I will credit you $20. Its OK I found you order and did a credit for you. One thing for the customers wanting to use existing mounting holes: if they were a bit off the OEM has slotted outer holes and gives you more leeway, ours may have to be slotted a bit if your holes were not placed exactly in the correct place, but that's easy. We can pre slot them like the OEM if you like for $25 or you may not need to do it at all because we do have our holes larger than the 8mm.
