10-26-2017, 10:14 PM | #1 |
17 ZL1 what a car....
Need ECU pin # for wideband if there is such a thing?
I purchased a wideband setup for my car, I have the Aeroforce Gauge. It's a Bosch LSU 4.9 sensor running through the aeroforce control box.
I want to see if there is a pin on the ecu that I can run the Brown wire that is the 5volt Signal. On some of my other cars we found pins that we could use and log the signal via the OBD2 port while tuning. I also just installed the Aeroforce with the E85 unit and I hooked that up to the 38 pin on the blue plug on the ECU and it logs perfectly.
2017 ZL1 -- WHT - A10 - PDR - NAV
Mods: Kooks 2", Lingenfelter 9.17” 18% Pulley, CAI, E85 sensor, and Interceptor Wide-band & Gauge with Pod, 180 Thermostat, BMR Rear suspension parts. |
10-26-2017, 10:19 PM | #2 |
Admin please delete post as I posted it twice... Thanks
07-24-2020, 09:05 AM | #3 |
Drives: firebird Join Date: Jan 2010
Anything on this?
07-24-2020, 12:58 PM | #4 |
SNSTRSS
2016 Black Camaro 2SS A8 NP
