Old 07-07-2019, 03:38 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Little bit of turbo advice please
So I bought my turbo, went with Huron and happy I did. Also, ordering the AGP fuel system and injectors. Got defroster vent pods and a boost and lambda A/F gauge. Stock motor. What else is recommended? I also got the E85 kit. I'm writing a build list and want to get everything I can up front. I guess a good catch can kit. What is generally the better can? Any thing else I'm missing?
gunchamp is offline   Reply With Quote
Old 07-07-2019, 04:31 PM   #2
mrimpala02
Drives: Black 2SS RS w/White Stripes
MM catch can seems to the agreed upon.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 07-07-2019, 07:29 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX427 TT
If you're going to put that newfound power on the track, where's your suspension mods?
In excess of 1,000WHP
LSX427 | AGP 65/65 TT | BTR Equalzer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | NGK BR7EF | DSX Flex Fuel Sensor | AGP's Fore Triple Fuel | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 07-07-2019, 09:59 PM   #4
gunchamp
gunchamp's Avatar
Eventually thats where I'm going. Any suggestions?
Old 07-08-2019, 12:08 AM   #5
dreksnot
dreksnot's Avatar
At minimum: trailing arms and toe links (rods)
Old 07-08-2019, 11:45 AM   #6
bayarea408
bayarea408's Avatar
Drives: 10' 2SS RS L99
Solid rear mounts like pegasus. Mighty mouse can works well for me. I bought a aeroforce interceptor gauge as well. There are scan gauges out now.
2010 2SS/RS -Huron Single Turbo Precision 76/75 cea
bayarea408 is offline   Reply With Quote
Old 07-21-2019, 09:30 PM   #7
-Im.z2ight-
Drives: 2013 Camaro 2SS "Diablo"
Twin turbo car here running the Mighty Mouse catch can.
Diablo - 2013 Camaro 2SS
Mod List: GM NPP Dual mode exhaust(Fuse pulled), AGP Twin Turbo 54/57, ZL1 Fuel pump with flex fuel sensor, ADM FPCM, ID1000 Injectors, diamond racing forged pistons, BTR twin turbo cam stage 2, Lunati forged H beam rods, BTR trunnions, ARP head studs, Vararam power wedge, MightyMouse Wild catch can, PFADT 1.25" drop springs, BMR Strut tower brace, 20x10.5 Giovanna Mecca rear and 20x9 Giovanna Mecca fronts, R1 Concepts drilled and slotted rotors, Hawk HPS pads, Night Owl RGB halo kit, and more...
Future Mods: Dual fuel pump and more...
-Im.z2ight- is offline   Reply With Quote
Old 07-22-2019, 07:34 PM   #8
Luvdamud
Drives: 2010 SS
aeroforce defroster vent dual pod and MM catch can on my twin turbo setup too.
White 2010 SS
Huron twins
4l80 conversion
Luvdamud is offline   Reply With Quote
Old 07-23-2019, 05:54 AM   #9
gunchamp
gunchamp's Avatar
Got the aero pod and all my gauges. Mm will be ordered very soon
Old 08-05-2019, 04:42 PM   #10
marine02ss
Drives: 2015 Z28
What specific catch can are you all running from MM
marine02ss is offline   Reply With Quote
Old 08-05-2019, 11:35 PM   #11
mrimpala02
I have the wild -12AN setup.
Old 08-06-2019, 05:03 AM   #12
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Suspension
Like dreksnot said trailing arms and adjustable toe link. Along with anti roll bar in back . remove front sway bay you will never notice it gone.
Then a front set of holley Lakewood strut 70/30 then rear 50\50 I can tell you how to use the factoryv8 don't use the v6 like they say. And good alignment.
My proof is in my time slips and mph and street runs you can be mid 9.xx on virtual stock suspension
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 08-08-2019, 01:37 PM   #13
bayarea408
bayarea408's Avatar
Tell us how to use the factory v8 what? as opposed to the v6 what? What kind of front runner are you on? Are the 70/30's rough on the street?
Old 08-09-2019, 08:39 AM   #14
jnmn
2&thahit
jnmn's Avatar
Drives: a black SS on sunny days :)
Pretty sure he means brakes
jnmn is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
