Old 08-13-2019, 12:20 AM   #1
PumpinIron
Drives: 2013 Camaro 2SS
Easiest way to get to 700hp on a ZL1?
What's the easiest way to get to 700 crank horsepower on an LSA engine?
I'm thinking of adding high flow, ported LSA heads from GPI, a smaller pulley (what size pulley should I run?), a GPI camshaft (for forced induction), a Roto-Fab intake, and then I already have fully ceramic coated ARH long tube headers and full exhaust.
Will all of that plus a tune put me around 700hp at the crank?
2007 Lingenfelter Corvette Z06
PumpinIron is offline   Reply With Quote
Old 08-13-2019, 08:03 AM   #2
WEISHAAR37
WEISHAAR37's Avatar
Drives: 2010 Camaro 1SS
is the car an auto or manual? and how are you planning to calculate it into flywheel HP?
i work as a tuner here at GPI, and for reference last week i made 548/548 in a 2015 ZL1 M6 car wth nothing but a 5% lower pulley and headers.
with more boost, heads, and a cam i would not be surprised to see 650 range from the build you have specd out.
give us a call anytime if you have any questions.
thanks,
Ben
WEISHAAR37 is offline   Reply With Quote
Old 08-13-2019, 08:28 AM   #3
PumpinIron
thanks,
Ben
The car is a manual.
My thought was that if the car put down something like 630-640 at the wheels (on a Mustang dyno), that would be around 700hp at the crank. The number isn't that important to be honest, but I have heard from others that that's about the most power you can expect out of the ZL1s factory blower.
I am in the process of speaking with Ronnie at GPI this morning, and I think I'm going to have him put together a package for me with heads, a cam, a pulley, etc. I think that should probably get me to where I want to be.
If I have to port the blower, I may just start looking at replacing it with a Whipple or Magnuson unit, as I know those units are higher flow (and more efficient) units to begin with.
Those numbers you put down on that 2015 ZL1 are not bad at all for just having a smaller pulley and headers, I'm impressed!
Old 08-14-2019, 07:37 PM   #4
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2013 ZL1 Blue Ray A6
Maggie 2350 is on my wish list..believe that is best for our cars vs. 28% overdriving the TVS1900..
don't forget fuel supply and cooling.
StreetRage320 is offline   Reply With Quote
Old 08-14-2019, 11:12 PM   #5
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Swap on a ProCharger.
I run a D1X Stage II @ 14psi on a stock L99 bottom end with auto trans and made 723 rwhp pump 93 and 760 rwhp on pump E85.
2010 CGM Camaro 2SS RS A6 760rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 2 CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 08-17-2019, 12:40 PM   #6
FieroItaliano85
Drives: 2014 2SS/RS L99
Your 6l80 is holding that power?
2014 2SS/RS AGP Twin Turbo
FieroItaliano85 is offline   Reply With Quote
Old 08-30-2019, 09:34 AM   #7
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Honestly man you're better off checking out the ctsvowners.com forum. They have the LSA's down to a science. DO NOT waste your money swapping blowers the little LSA if VERY efficient and is capable of 800+ rwhp maxed out of course.
Also about 605 rwhp will put you right at 700 crank. Check out this link to get an idea of what people are doing to achieve this number.
https://www.ctsvowners.com/forum/4-e...s/36454?page=1
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
