![]() Drives: 2015 Camaro ZL1 Join Date: Dec 2022
Dyno numbers
Wassup y’all. Just seeing if this is about right for what mods I have on my 2015 zl1. I have the following:
1000cc fic injectors 5” RPM cold air intake (this thing sucks?) 2.50” upper pulley Catless long tube headers PLM heat exchanger I made 530hp/540tq. This is about stock numbers right? I’m running on 91 octane. Am I missing something or does this look about right? The tuner said the 5” isn’t good and it’s really hard to tune.
Catless 1 7/8” kooks long tube headers, TR7IX spark plugs with MSD spark plug wires, Rotofab CAI, washer fluid relocator, metco solid isolator, 2.50” upper pulley, PLM heat exchanger, LSA reinforced brick, elite engineering catch can, FIC1000 injectors, DSX flex fuel, DSX aux pump, custom dyno tune
![]() Drives: 2015 zl1 m6 Join Date: Jan 2020
You an auto or manual ? As far as the rpm5” cai . My tuner told me unless you have a 416 or bigger was not needed . Your cylinder can only fit so much air and fuel . I’m 800+ whp on E with a regular rotofab w/ 103mm tb
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
Auto, I’m looking at the rotofab too. Gonna go E too. Any suggestions that could get me some more power? Thing feels stock still lol sounds mean tho
#4 | |
#5 | |
#6 |
![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
a stock automatic zl1 only makes around 460 whp. so you are far from that. If you really want to make more power you'll need a cam and a lower pulley. As far as the RPM intake i have it also and lost some power coming from a jlt 5" intake but different day and summer time tune. but i does make adding meth injectors much easier with the built in bungs.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
#7 |
I did this modification to let it breathe even more. I ordered a new fog light bezel so i have the original to replace it if needed.
#8 |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
#9 |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
E85 works really well on these cars, but you going to need an AUX pump or bigger fuel pump.
#10 |
I have the DSX E85 flex kit and plan on getting the DSX aux kit. And going to go rotofab cold air intake and sell my 5” RPM intake. I live in Cali so camming it kinda scares me haha. Might yolo it though. Thanks for the input guys. So it usually is 460 wheel for autos stock? I never did a base run so I thought it was around 500. Guess I gained about 70 wheel then
