05-06-2016, 12:15 AM | #1 |
Milkster
kill the squeak
front rotors replaced.. continued using old pads.( good condition still) squeaks terribly.. what do i need to do ... added grease and spray squeal be gone stuff... helped for about 1 week
05-06-2016, 12:23 AM | #2 |
Similar situation so I am also curious ..
05-06-2016, 02:24 AM | #3 |
did you ruff up the pad befor you put it back on?
05-06-2016, 07:48 AM | #4 |
Drives: 1996 Camaro Z28, 2012 2SS/RS Join Date: Aug 2012
It's all about the metal to metal contact. All the clips and pins as well as the back of the pads need the grease. Lots of it.
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
05-06-2016, 10:44 AM | #5 |
Milkster
ive put soo much grease on it..
05-06-2016, 11:04 AM | #6 |
'It's an experiment'
This and did you bed in the brakes? There is a series of steps to transfer pad to rotor to help with this. Rough up the pads and rotors to bed them in if the pads are reused. I'd try that first...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 05-07-2016 at 06:17 PM. |
05-06-2016, 11:37 AM | #7 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
You need to bed the brake pads and rotors to each other.
http://www.tirerack.com/brakes/tech/....jsp?techid=85
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-06-2016, 11:55 PM | #8 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Like others are saying, bed the pads. A lot of noise has to due with the variances between the pads and rotors. Being that the rotors are new, but the pads are not and the friction material is matched to the old rotors. Greasing is good, but you can grease everything but nothing will fill the voids between the old pads and the new rotors.
More to come. |
