10-26-2016, 04:49 PM | #1 |
Drives: 2010 ss Join Date: Oct 2015
flex fuel on ecs at 604rwhp
OK this is the question..I am making 604 whp now,I have BAP and zl1 pump,with ID 850s.Am I good to do a flex fuel tune,or am I going to run out of fuel?the 604 is on 91 gas.Turner said maybe another 40hp.Thoughts??
10-26-2016, 05:29 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Don't think so. You'll need more fuel just to hit the same power, and I'm presume you're already at your limit there.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 10-26-2016 at 05:45 PM. |
10-26-2016, 05:37 PM | #3 |
Too much is never enough!
Ya, not enough, need more everything.
10-27-2016, 09:08 AM | #4 | |
If you want to make 650 on pump fuel your system is OK. If you want to move to flex fuel you will need a complete Squash or Fore fuel system, Flex fuel sensor kit, and ID-1300s. then 10-12 hours of labor to install everything, then custom tuning. I am always available to help with builds. Ted.
www.jannettyracing.com
10-27-2016, 10:28 AM | #5 |
Drives: 14 1le turbo Join Date: Oct 2015
how far can 1300s go on e85?
2014 1LE 2SS/RS
Huron Speed turbo kit |
10-27-2016, 10:46 AM | #6 |
It would depend on fuel pressure, auto or manual, but at 4 bar around 1000 RWHP
10-27-2016, 09:43 PM | #7 |
the tuner wanted to do a flex fuel tune,glad I didn't do it.What would I need if I added more boost with the 91 fuel,meth?I can get another 3pds of boost if I pull the restricter in the filter
10-28-2016, 06:33 AM | #8 | |
Adding more boost requires more fuel, If you add one of our FPCM your fuel pump can handle up to 700 RWHP of fuel supply on E10 gasoline. Where you are limited is Octane at this point. If E85 is available although the initial investment is large the safety, and HP benefits are well justified. The Octane, and cooling effect make it very easy to run 13 PSI on an otherwise stock engine. For this you would need a Fore or Squash return style fuel system rated for at least 1K hp on E-85, a set of ID-1300 injectors. Meth kits are an option but higher risk and more baby sitting than I would want. A true Flex fuel conversion is the best option with the parts I mentioned. Feel free to give me a call and I can answer all your questions and help you decide what is best for you. Ted.
10-28-2016, 12:50 PM | #9 |
thank you guy!!! curt
10-28-2016, 12:50 PM | #10 |
Drives: 2010 Exige S260 Join Date: Jul 2016
+1 for Ted
10-28-2016, 01:24 PM | #11 |
I made 650 whp on 10lbs with 93 only. Zl1 pump and fast 85# injectors. No BAP. My pump was basically maxed out tho.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
10-28-2016, 02:28 PM | #12 | |
Not Proper fuel pump control module and Less than desirable injectors. Sorry for your loss.
10-28-2016, 06:04 PM | #13 |
I'm pretty sure he had twin 450s when it popped. Car made 889rwhp. I'll let him finish the story.
2014 1LE 2SS/RS
10-30-2016, 08:50 PM | #14 |
Drives: 1996 Camaro Z28, 2012 2SS/RS Join Date: Aug 2012
I have FAST 85# injectors with Fore Inovations twin pumps and Meth with Flex fuel sensor and making 675 rear wheel running E85. 12 to 13 lb's of boost. I think I'm maxed out tho. The pumps and labor are expensive.
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
