Old 03-11-2018, 09:20 PM   #1
Mystic27
Drives: 2002 camaro ss
Mystery LS1
I have a 2002 slp 35th aneversery ss t tops 6
Basicaly i bought from a gm dealer here
In winnipeg . It has alunimun harmonic
Balancer and a 6.5 quart oil sump. Head are
241. Basically it the fastest car i ever drivin
It will pull hard past 6000 rpm . I am the
Original owner . I have done no mods to it
Any body had any idea what under the hood?
It not a LS1 as it easy out run a LS1 and it vibrates
Like it had a can in it. Plugs would foul if u let it
Idle very long
Mystic27 is offline   Reply With Quote
Old 03-11-2018, 09:24 PM   #2
Can'tHave2MuchHP
@ Genesis Chevrolet
Can'tHave2MuchHP's Avatar
Drives: 2018 Camaro ZL1 A10 Coupe in White
Did you confuse LS1 with ZL1? You're in a section where you'll probably receive no help. I'd try a 4th gen section.
Current Garage:
2018 Camaro ZL1 | A10 | White | Coupe | PDR | Nav | Carbon Fiber
2017 Corvette C7 Z06 | A8 | Black | Z07 | 3LZ | Carbon Fiber
2013 Corvette 427 | M6 | White | Convertible | ZR1 Wheels
1973 Camaro Z28 | M5 | Blue | 383 SBC | Frame-Off Resto-Mod
1970 Corvette 454 | M4 | Red | Convertible | 454 BBC | Frame-Off Restoration
Can'tHave2MuchHP is offline   Reply With Quote
Old 03-12-2018, 12:03 AM   #3
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6
You can tell buy the casting numbers, if its an ls1. You could also get a cylinder camera and check the pistons to see if they match with an ls1 piston or if they are aftermarket. As far as a cam goes, pull of the timing equipment off and look at the front of the cam, usually aftermarket companies have some type of engraving on their cams.
2011 IOM 2SS LS3 M6- Injen CAI, TSP 1 7/8 longtube headers no cats, ported and polished TB, Hurst short throw shifter, Diablosport Trinity, Corsa catback exhaust, 20" TSW Nurburgrings w/ 315s on the rear, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. Tuned by me
WVracer is offline   Reply With Quote
Old 03-12-2018, 12:48 AM   #4
Mystic27
Where would i find the casting # ?
There is no # on the block where the
Manual say it belongs?
And thanks a lot for the help. Forums are very
Difficult for 59 year old man
Old 03-12-2018, 01:59 PM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Pic would help
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 03-12-2018, 07:48 PM   #6
WVracer
WVracer's Avatar
All LS blocks should have the block displacement casted on front and rear of the block on the cylinder bank. Is the throttle body a 3 bolt or 4 bolt?
Old 03-12-2018, 08:47 PM   #7
Mystic27
Will get back to you on that
Old 03-12-2018, 08:48 PM   #8
Mystic27
There is no casting #
Old 03-12-2018, 09:10 PM   #9
Mystic27
The TB is held on with 3 bolts
Old 03-12-2018, 10:11 PM   #10
Mystic27
This is the ss
Old 03-12-2018, 10:12 PM   #11
WVracer
WVracer's Avatar
With 241 heads and a 3 bolt TB, its definitely looking like an LS1.
Old 03-12-2018, 10:13 PM   #12
Mystic27
This is the birth certificate
Old 03-12-2018, 10:15 PM   #13
Mystic27
The car still looks as it was in the picture
Old 03-28-2018, 02:17 PM   #14
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
never seens a LS engine with aluminum balancer. There should be casting on drivers rear of block around where head is. SLP pretty much did bolt ons - exhaust, air intakes, hoods/spoilers and wheels
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
